« 1 2 (3) 4 5 6 ... 8 »
Re: S13 brakes onto b110 struts. booyah
From Brisbane, Australia
SOME 13" wheels will fit over S13 calipers. these neg offset superlite do, but most 13" wheels probably won't - they're likely to foul on the bleed nipple.
for those who are interested 12" mags will fit over Stanza brakes - the ones I used were Superlite 12*5".
Posted on: 2008/3/3 1:17
if you go to a jap wrecker you can pick up 14 inch space savers for 4 x 114 cars from silvias and 180sx'x etc. usually $50 a pop. as long as just for a spare, it will do the job and will be thin enough. Think if you look hard enough might even find them in 13 inch.
Posted on: 2008/3/3 5:08
From The garage, NZ
My 13x7 -8 (think that was it) superlites fit fine.
Posted on: 2008/3/3 5:13
From Christchurch NZ
I think it depends of the bolt height spacing on the caliper plate. I have u13 bluebird rear discs on my 1200, and 13's fit fine. A mate of mine has the same discs on his 510, and he tells me 13's wont fit. I think it'll work if the caliper is close enough to the rotor.
I'm getting a pair of rotors and calipers tomorrow for $50
Posted on: 2008/3/3 5:36
Forced Induction!
yeah, that's what I was referring to. Most 13" wheels used on Dattos willl have positive offsets to, so its not a very good basis to say that 13" wheels will fit based on that example.
Posted on: 2008/3/3 6:42
From The garage, NZ
yea true... BUT MY 13" WHEELS FIT haha jj
As stated before, not exactly needed that much on a standard car and when undertaking the converision is expected to be because of better suspension/engine etc so running lame offsets are always used.
Posted on: 2008/3/3 6:46
From Castro Valley,CA USA
Then today is your lucky day, go play the lotto
I actually like this brake set-up and I'm sure other 13" wheels will clear. I just wanted others to be aware that some 13's might not. You should check.
FWIW... I think my wheels have about a +12mm offset and about 100mm backspacing.
Posted on: 2008/3/3 7:05
From The garage, NZ
standard b310 13" steelies dont fit. Gutted becoz they were going to be the spray the car on bikies
Posted on: 2008/3/3 7:24
Bolt them on back to front
Posted on: 2008/3/3 8:14
Forced Induction!
From Geelong, Vic
geez dodgeman, id hate to see how long your post would be showing how expensive it would apparently be to built my car
Posted on: 2008/3/3 11:53
