Camshaft - what will GX valves spring handle?
From Las Vegas USA
OK shot in the dark:
I've got a camshaft in the parts bin that is .450 lift and 286 duration, I tempted to use it BUT not sure the standard GX springs will handle this as the ramps look pretty steep. So anyone know what the limit is for the GX dual spring set up?
Tom
note with the GX cam it will buzz to 8k , finally floats at 8150
Posted on: 2008/3/6 2:01
Re: Camshaft - what will GX valves spring handle?
From Los Angeles,CA. USA
Why don't you just install a new set of Isky dual valve springs...I have 5 new sets sitting in the shelf!
He has them in stock...
Posted on: 2008/3/6 2:06
From Burbank, CA
what else is needed to put the double valve springs on? for a regular A15?
Posted on: 2008/3/6 2:41
|||\ 81 KPB310 /|||
