witch is the best model to race withe?
From portugal
I mate
Posted on: 2008/3/31 16:05
Re: witch is the best model to race withe?
Mozambique: 1200 Truck
Bonneville: 1200 Coupe
1300 Cup: 1200 2-dr sedan
Demolition Derby: 1200 4-dr sedan
Drag Racing: 1200 Wagon (Van)
Posted on: 2008/3/31 17:36
From portugal
whell, it
Posted on: 2008/3/31 18:00
The 2-dr sedan is the lightest, so use that. Lighter weight = faster acceleration.
Posted on: 2008/3/31 18:08
From portugal
ok... but dosen
Posted on: 2008/3/31 18:21
From sydney australia
Second the motion for the 2 door sedan (thats committee speak for i agree). Not only is it a lighter car,you can fit flares easier & probably get bigger tyres under the back even before the flares. There can't be much difference in the weight distribution between the 2 sedan models, but you could always move some of the accesories to the rear, like the battery, if you want to.
Posted on: 2008/4/1 1:19
From Adelaide, Australia
Best model to race with? Coupe hands down, lower roof line, (I would of thought the coupe to be lighter than the 2door sedan?), easier to fit flares and gain wheel clearance, and most are assembled in japan so they seam sealed them much better and are much more intact these days.
I don't like the coupes though, my first car was a 1200 coupe, and I always thought it looked like a 120y.
Posted on: 2008/4/1 8:49
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
From Sydney, Australia
I second that..
2 Door sedan all the way. But I would like to race a 2 door VAN...345 tyres on the back under full tubs..niiiice.
Posted on: 2008/4/1 9:26
WhiteSedan, your pluses are for the 2-dr sedan:
> lower roof line
True (40 mm) but the 2-dr sedan has better aerodynamics if you lower it to the same height
2door is lightest
Ditto for 2-door.
Ditto for 2-door.
But the difference is oh so slight. Coupe is just as good.
Posted on: 2008/4/1 10:11
From NZ
I race a 1200 Coupe but the sedan has better rear suspension set-up to start with - vertical shocks vs the Coupe's which are angled and really need to be turreted (but I haven't yet done mine).
Posted on: 2008/4/1 10:49
