well im planing out an a15 turbo project
so far what i have come up with
a15 block
full rebuild
copper head gasket?? are they readily availible or do i a custom one made?
std bore, pistons and still thinking of ring possibilities (any suggestions?)
balance job on all spining parts
cam? sugestions please
a12 gx head
replace anything that needs it
L16 valves
port job polish etc
anything else that would be advised?
ignition will be a modified ford EDIS unit
will be using frankthedolphintrainers manifold
so im going t25 or t28 or hybrid? which is beter? input please
thinking of quad throttle bodies off an 07 yamaha r1 or would i be better off with one single thrttle body?
and the main question what injector size would be ideal?
computer will be a megasquirt II which allows the use of the ford EDIS ign unit (thought i might add if any didnt know how i would be controling the spark
please post your thoughts on this and any suggestions
