Mini Spool
Hi,
Has anyone on here used a minispool on their H165?
Are they available?
Marty
Posted on: 2008/6/12 22:30
Re: Mini Spool
From SE Melbourne
I'd be interested in the answer too - I've a H165 behind a CA18DET - and will also consider a mini spool rather than welding it up.
I've had a google to no avail.
Posted on: 2008/6/13 9:19
Mildman, Datsunless
Re: Mini Spool
From Canberra
topgear suggested he could make them if there was enough interest. My mate was looking for a minispool for the r180 in his s13, I think the only one he could find was going t be ~$1000 from Japan... out came the welder.
Posted on: 2008/6/13 9:26
Re: Mini Spool
From Canberra
double post
Re: Mini Spool
From Rosewood, QLD
i think i have a h165 in my ute... how badly does the weld locker damage the diff?
Posted on: 2008/6/13 12:29
Re: Mini Spool
When you weld it not much else can happen, unless the weld breaks!
Posted on: 2008/6/13 12:58
Re: Mini Spool
From SE Melbourne
Good thing about the mini spool is
1. Reversable
2. I think makes better contact with axels - less likely to break axels...
There is a company called Lokka that make them in melb - I guess we could ask them...
Posted on: 2008/6/13 13:01
Mildman, Datsunless
Re: Mini Spool
From windsor, sydney
hi guys i work for a company in sydney that makes custom diff stuff for any thing you want . a full spool is better than a mini spool because a mini spool is still driving through a single cross pin that is unsupported between the spool insert and the hemi case , wich leeds to pin failure in anything with decent grunt . a full spool even a one off custom is under $800. Might sound expensive but you will never have to touch it again . are you driving this on the road ? a spool or a welded locker is not recomended for road use . any intrest PM me for more details.
Posted on: 2008/6/13 13:42
Re: Mini Spool
From Rosewood, QLD
yeah im a daily driverso ill stick to saving up for a shortened LSD R31 diff.... maybe keep the H165 and spool it for other purposes...
Posted on: 2008/6/13 13:49
Re: Mini Spool
From W.A.
I have been driving around for about 3 weeks now on a welded diff, i have not yot tried it out on the track but even on the road i feel like i am in more control. when i put my foot down round a corner it powers through where as before, it felt like it coasted around corners. Even in the wet it feels good (driven carefully) before was a nightmare to get traction. I should have done it ages ago (i had nothing to loose as i have 2 h165).
can't wait to try it on the track so i can keep power on through the tight corners as my inside rear wheel always picks up of the ground.
maybee the best $0.00 i spent yet.
my opinon is as mini spool's are illigal why waste you money just weld it up with some plates in the center (nice and strong).
drive safe.
Posted on: 2008/6/13 17:00
