a12 engine troubles
From Toowoomba, Australia
well i done some damage to my engine this arvo i put a 350 holley on it and it was running heaps better took it for a drive all of a sudden it died in power then stoped. Parked it in the shed got it started and No. 2 cyl wasnt firing and smoke was coming out of tappet cover breather ive put it down to melted piston broken rings or a head gasket. doesnt seam to be running lean and it only running 3-4 psi
can any one help with a daiganosis before i go tearing it down
Posted on: 2008/6/15 9:58
The substitute for cubic inches is forced induction....
wanted fender mounted mirrors 4 120y
& 120y hubcaps
120y 2dr every day driver
120y 2dr project
Re: a12 engine troubles
Wet and Dry comp test should give you an idea if it is a piston or excessive carbon deposits on the valve, blown head gasket etc. First comp test dry. Second test put a few squirts of oil in the affected cyl with an oil can. If comp raises with the wet test then it is a bottom end (ring) problem.
Posted on: 2008/6/15 10:29
From Croydon Victoria Australia
Isn't a 350 holley a little bit of overkill on an A12 ? Just curious...
Posted on: 2008/6/15 10:49
From Darwin NT
pretty sure its turbo and you can jet the carby down to suit the motor.....
Posted on: 2008/6/15 11:07
current project 4x4 patrol...
took the head off and found that iv done the rings in the No. 2 & 3 will post some pic aswell so now it time for a rebuild. other than that the engines in good nick also found out that the head was a high comp one to and about the 350 been to big the engine is turboed so not really and it goes much harder than it did with the stock carby and a webber
Posted on: 2008/6/15 12:39
& 120y hubcaps
120y 2dr project
Posted on: 2008/6/15 12:57
& 120y hubcaps
120y 2dr project
Not too shy to talk
From Mid North Coast NSW
Posted on: 2008/6/16 0:54
What did you see that makes you think that the head is a "high comp one"
To be honest, it looks completely standard to me.
Posted on: 2008/6/16 3:57
Love your Datsun.
Treat it well.
Didn't realise she was running a turbo...
Posted on: 2008/6/16 4:36
Not too shy to talk
I'd weld up that water port while ya got the head off, she's getting close to #4
Posted on: 2008/6/16 5:14
