« 1 (2) 3 »
Re: here we go again...Brakes
As every one is talking about brakes here, i want to make a Question...I have a 79' 120y(It is my first Datsun) and I want to improve the brake system (MC, front & rear, piping, etc) what kind of swap shouth I Do?... is there an easy way to put rear disc brakes?...Thanks!!!
DATSUN RULES!!!
Posted on: 2003/6/12 16:28
From Charlotte NC USA
go Z the struts are short and have big disks then install a set of toyota hilux calipers they come on the 77-79 4x4 hilux here in the states
this is the setup I am doing on my 120y
Posted on: 2003/6/12 21:41
Phil (aka nutcase)
I have C.L.W.E.A.
Can't Leave Well Enough Alone
120y exelant clone gone :(
Thank you Nutcase, so I can use any Datsun Z struts and Hilux Calipers...thats for the front end, any idea for a rear disc swap?...I'll use the Z's and Hilux on my 120Y Wish me Luck!!!
Posted on: 2003/6/12 22:26
From Brisbane, Australia
nutcase, have you done the Z car strut swap?
They have a wider bolt spacing at the base than other Datsun struts, so you'll have to get the Z steering arm as well as a minimum.
What lower control arm/ball joint did you use?
Did the 1200 outer tie-rod end fit the Z steering arm?
Posted on: 2003/6/13 0:57
From Las Vegas USA
If you are just wanting better brakes Wilwood makes a caliper called a Dyna-light these come in 2 and 4 pistion. US hot rodders use them because the will fit over 1/2 thick non-vented rotors price is $125 US.You would have to fab a carrier but that is easy as you will just need a flat plate.
Tom Grossmann
Posted on: 2003/6/13 1:07
From Sydney
Dude..... I know that the disc brake set up may look good and pending how good you are with spanna not to hard to convert but honestly weather it is track work or whatever there really isnt a lot of difference from drum to disc on the rear of a small car.
Reason being is that under braking either hard or soft, you transfer the majority of the weight to the front of the car (pivoting) meaning that your rear brakes do little. Unless you are going to have adjustable brake bias which most track cars will have you are better of spending your money on some go fast bits or for that point better front rotors or calipers maybe...... only a thought i hope it helps
Cheers
Peddler
Posted on: 2003/6/13 2:26
From Melbourne, Australia
BULLSHIET to both peddler and nutcase!!!!!!!!!!!
peddler try driving without back brakes, they do heaps, my backs wernt working for a couple of days and the ####in fronts lock up so much i couldnt stop for anything in a hurry (if the lights changed i had to just keep going through), ended up hitting someone elses car on day 3
and nutcase you make the conversion sound easy but it is a BIG job your talking about, you have to change discs, spring cups, machine calipers, prob make up castor rods (not sure bout steering arms), find springs that sit the right height.
i have pics of hi-lux 4 spots on my stanza struts and with vented discs, i know what is involved and have also considered using 240K struts and have heard whats involved in fitting these, it definately is not a case of just switching over like you seem to imply
Posted on: 2003/6/13 9:29
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
as far as discs on the back, have a look at my site
for a couple of options
but with the stock diff you are pretty much stuck with what you have
you havent got the borg warner iff in your 120y i am pressuming?
Posted on: 2003/6/13 9:42
1200 Coupe Rallycar
"you havent got the borg warner iff in your 120y i am pressuming?" excuse my ignorance 1200rallycar; But, What are U taking About?...Borg Warner what? (iff or diff?) i'm new with Datsuns could u please be clearest? i really don't understand
But Thank you, i'll maybe understand if u teach me!! BIG Thanks!!!
( Excuse my english )
Posted on: 2003/6/13 16:33
From Sydney, Australia
He meant to type Diff (Differential). The 120Y's in Australia came with an Australian-only Borg Warner Diff. The imported ones had a smaller diff.
Dilop, where are you from?
Cheers,
Chris
Posted on: 2003/6/14 6:15
« 1 (2) 3 »
