« 1 (2)
Re: wtb: Armstrong 120y struts
From Adelaide, Australia
Very interesting... so it doesn't say armstrong on it at all? There should either be atsugi/tokico/armstrong/monroe or some brand stamped on the tube.
Posted on: 2008/7/17 9:05
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
From Gatton, QLD
not that I could see. The strut is a bit dirty but couldn't see anything else. The sunny strut had more stamped on it but this one only the number 7601
Posted on: 2008/7/17 9:58
From Quairading, Western Australia
I wish I knew the stubaxle size for PB210's...
as the struts I just put into the The Defect III were japanese manufacture... ie Tokico
they do have the larger diameter stubaxles too..
I also wish I knew the balljoint sizes for PB210's too
I am thinking thatn Aussie 120Y sedan suspension IS PB210 based...
no my struts are NOT for sale
Posted on: 2008/7/17 11:01
From Canberra
based on what?
Posted on: 2008/7/17 11:04
larger stub axle size, bigger balljoints
and these struts I have have an adapter to bolt the caliper to the strut...
the Jap strut caliper bolts straight to the strut...
ok I should have been more clearer - I think the struts on MY 120Y are PB210...
the gearbox in TD3 ended up being a F4W60L...
and the struts came off a 120Y that was a stock car...
so I don't know if the front end is something exotic or not...
Posted on: 2008/7/17 11:18
I dont think you have anything exotic mawler...
from what I have seen all the later model 120ys have the sunny/stanza lower arm, large size balljoint like a B120 ute (shorter than stanza), castor rods that are shorter than stanza same length as early 120y and larger stub axle like a stanza (same bearings etc).
These 120ys can either have aussie struts with PBR calipers or jap struts with jap caliper.
Posted on: 2008/7/17 11:50
IPRA Build
From Gatton, QLD
Yeah thats what I'm chasing. No one got any near brissy-toowoomba area?
Posted on: 2008/7/30 11:34
From Gatton, QLD
no ones seen any at the wereckers in area either?
Posted on: 2008/8/15 0:18
From cranbourne, vic
theres a drivers side one here in vic at harveys wreckers (somerville??), ds only, half the caliper is missing (part that holds the pads), disc isnt much good and i pinched the one piece flexable brake lines i dont think theres any control arms or bj's and i got the sway bar aswell...
Posted on: 2008/8/15 9:38
82 1200 ute - daily
89 R31 H.M.A.S. Skyliner - drifter
197? 1200 coupe - new drift project.
85 CMA81 nissan/ud 9.5ton banana back - tow pig for the drifter.
From Gatton, QLD
yeah vic's a bit far but thanks anyway
Posted on: 2008/8/19 2:39
« 1 (2)
