conversion help
From brisbane, QLD
hey guy's does anyone know if or wat the break upgrade standards are for a 1200 ute to be road worthy for a ca18det conversion..
Posted on: 2008/7/30 11:31
Re: conversion help
From Melbourne, Oz
Not sure of the acctual rule's but I emagine if you had something roughly equivalent to the car the motor came out of, that would be a good start.
Posted on: 2008/7/30 11:36
"I hav achieved wood"
Re: conversion help
From Melbourne AUS
in a 1200 ute 120y disc front as a minimum.
although i dont recommend them for anything more than (legal) street driving...
Posted on: 2008/7/30 11:37
1973 B110 A12
Re: conversion help
From Melbourne AUS
oooops double post
Posted on: 2008/7/30 11:47
1973 B110 A12
Re: conversion help
From newcastle, NSW
i was told the rule of thumb is you are suppose to use the brakes that was in the car the engine originally came out with to be properly engineered and to be confident in your car to brake sufficently when needed, i used the 120y disks in my blue coupe and it was VERY hairy on the track! i wouldn't recommend using the standard 120y disks, you should be using stanza or 200b at a minimum in my opinion! Also depends on the purpose of the car.
Posted on: 2008/7/30 12:22
Re: conversion help
From Nyngan, nsw Australia
Ive done R31 struts with 1200 spring perches, even though the 1200 perches are small i machined out the center to fit skyline strut, also allows the car to sit lower roughly 2"
The control arm is the next thing to nut out, skyline, 200b, gazelle control arms they bolt up the same,
the outer tierods are also diffrient sizes, thats what i have that at the moment to play with,
the booster.....well that another thing!!
what diff you using?, im using R31 skyline diff from a wagon 3.89
Posted on: 2008/7/30 23:05
Re: conversion help
From Brisbane, Australia
you mean apart from your engineer?
Posted on: 2008/7/31 0:36
Re: conversion help
From Geelong, Vic
hotrocket, r31 struts bolt onto stanza steering arms....so just need all the same stuff as for a stanza strut swap plus a sheer load spacer ring to locate the strut properly on the steering arm
Posted on: 2008/7/31 4:17
Re: conversion help
PIGDOG wrote: a sheer load spacer ring to locate the strut
A "sheer load spacer" aaa.........well you better gimmy a lookc at that so i can get one or make it.......
Posted on: 2008/7/31 9:22
