14 inch skyline / pintara rims ???
From Mandurah, Western Australia
The steel 14 inch rims off the Skyline R31 / Pintara. Anyone know the rear space measurement of these rims ???
Cheers
Posted on: 2008/8/7 13:28
Re: 14 inch skyline / pintara rims ???
Its a long shot, but anyone using these rims on Stanza struts? And could possibly give an indication of the gap between the wheel and rim
Checked wiki but it not detailed. ONly says these rims will fit and they aint to common in WA to track down some.
Cheers
Posted on: 2008/8/8 13:16
From Geelong, Vic
they fit on, and at a guess (assuming same sorta clearance as r31 alloys) will give only about 5mm clearance to the strut
if no ones got an answer for you tomorrow ill try to remember to do some fitting and measuring when i go out to dads
Posted on: 2008/8/8 13:36
From Brisbane, Australia
can't tell you the backspace on them - it was too long ago that I used them, but here's a pic of theses wheels on stanza struts on my old 1200 coupe when it was a road car. They're a great for for the front, but sit in heaps on the back. I had my rears modified to sit 20mm further out. I think it had 185/60 front and 195/60 rear in this pic. front gaurds were lipped.
Posted on: 2008/8/9 1:21
I had no problems with the 120Y on stanza front struts but on the rear they scrubbed also, mainly on steep angled entrys where the diff ended up on a bit of an angle. All fixed now though. Guess how... All right I'll tell you... Jelly beans!! They can fix anything. A sh1t looking car. A healthy marrige. You name it.
Posted on: 2008/8/9 1:35
found a pintara steelie under the house - must have been on the 120Y coupe when I bought it. backspace 112mm, and approx 17mm clearance to a stanza strut.
Posted on: 2008/8/9 3:56
cheers guys , will try and track one down to see how it goes
Posted on: 2008/8/10 11:49
if there the rectangular hole 1s theres a set at wreckers near mine if any1s intrested???
Posted on: 2008/8/10 12:38
