what engine to put in a 1985 corolla
Not too shy to talk
From Melbourne, AUS
does anyone know of any decent engine that'd fit in a 1985 toyota corolla? any old supra or MR2 engines or anything?
Posted on: 2003/6/9 9:55
Re: what engine to put in a 1985 corolla
From Sydney, Australia
If you are sick enough to want to modify one of these things, stick to the 4AG style engines. They are the Toyota 4 cylinder equivalent of the SR20.
The problem with FWD cars is that they are horrible to drive. They are designed for A to B only. But hey, spending money is what makes the world go round..so go for it.
Chris
Posted on: 2003/6/9 10:14
From Canberra, Australia
4agze. thats the s/c version...
Posted on: 2003/6/9 12:24
1971 Datsun 1200 Coupe
A15 Engine. Holley G180 (32/36 Weber). extractors and 2 inch exhaust.
Standard 1200 4 speed with lightened fly wheel and HD clutch
Stanza front struts and brakes.
15x6 CSA Wheels with 195/50 rubber.
From Melbourne, Australia
the 16 valve 4age is aparently the best way to go, its only slightly less power than the s/c standard, but apparently it has a lot of potential
i have heard the 20 valve is hard to work and you can actually get better purformance out of the 16 valve
my bro-in-law just got a sprinter and is planning this conversion, ive heard heaps about it, he keeps telling me bout the struts and brakes his using and eveything but i dont thimk that will aplly to your corolla
Posted on: 2003/6/9 15:07
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From sutho shire
from personal experiance i would go the 4AGZE its supercharged and replace it with a turbocharger mate done this in sydney and as said it is FWD not my fav either but he's goes good enough 2 get a v8 which isnt 2 hard but he was stoked as i helped him wit the engine conversion! u can pick up those motors really cheap 2 what area are u in?
Posted on: 2003/6/24 5:27
*1200 ute ca18det (CYA-18T)
256 rwhp at 14psi wanting more power
Team New skool
I would also suggest a 4agze, you could get the complete front cut for about 1500 dollars. Although a later model AE101 is ok if you got a AE92 one you could use the brakes shocks gearbox etc from the front cut. You will find that you need a converter for the tacho as they only read 1/2 revs. Be sure you get a coil pack one and not a dizzie one. On 14psi that should get you a mid 14 as you get nevo pulley upgrade kits. I would suggest the following sites.
www.toymods.org.au
www.twincam16.com
Posted on: 2003/6/24 6:51
I think the question is...."what lake to put a 1985 corolla in?"
Sorry, actually i don't know what motors will fit
Posted on: 2003/6/24 7:18
Datsun 1000 ute - Building (slowly)
Datsun 1600 13B turbo - coming soon
