help with rim offsets??..
From cranbourne, vic
ok ive read heaps of info on rim offsets and it still confuses me!! so i need someone to conferm this for me...
13 by 6jj (total width of 165mm) with a +15 offset = a backspace of 97.5mm ??? am i on the rite track??
Posted on: 2008/9/13 9:49
82 1200 ute - daily
89 R31 H.M.A.S. Skyliner - drifter
197? 1200 coupe - new drift project.
85 CMA81 nissan/ud 9.5ton banana back - tow pig for the drifter.
Re: help with rim offsets??..
From Canberra
sounds right to me... 0.5x165+15=97.5
Posted on: 2008/9/13 10:58
thanks.. i wasnt sure if i was calculating it rite.
Posted on: 2008/9/13 11:36
82 1200 ute - daily
i never understood back space and its importance, i used t believe in just offset, know i have learnt something for the day
Posted on: 2008/9/13 13:47
From The garage, NZ
+15 on a 6 should fit no problem unless your running offroad 4x4 spec sidewalled tyres.
Posted on: 2008/9/13 22:00
From Sydney
I think the backspace figure is far more useful than the offset figure. The offset figure often confuses many as the offset figure alone will not tell you if the wheels will fit the struts as it is dependant on the rim width. The backspace figure is easier to use as with our B110 you are in the zone from ~ 110mm - 125mm.
Posted on: 2008/9/14 0:25
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
agreed, back space is a lot more reliable than offset to ensure rims fit out 1200's. especially once you factor in stanza front disk conversion etc.
Posted on: 2008/9/14 7:52
ive got 13x6 jelly's with 115mm back space and the 175 pirelli's have about 3mm side wall clearence on the b120 drum struts
Posted on: 2008/9/14 11:14
82 1200 ute - daily
Mmmmmm... Jellies!
Posted on: 2008/9/14 11:25
revvy, you should seek some help about you sad, sad obsesion
Posted on: 2008/9/14 11:36
82 1200 ute - daily
