« 1 (2) 3 »
Re: Engine conversion day1....
From Auckland N.Z
buy a crapy disposable camera and get the pics put on to cd at the lab, only costs $10. Do you need to change the drive shaft? if not still get the original ballanced. i did this on my escort when changing engines, it was really out of ballance, but then again its a ford so youve got to expect that.
Posted on: 2003/6/24 13:18
From Brisbane
no i am on a laptop 120km's west of townsville, it got no msn (dads work lappie).......
DUDE you are 9 Post's!!!! away!! i say we call you "DATSUN DEMENTED" for reaching 2000 posts in a very short time
Posted on: 2003/6/24 13:19
OLD SkOOL POWeR!!! [color=CC0000]"with the sound & smell of twin 40s at full throttle!!!" [/
From Brisbane
i have to get the tailshaft cut down to get in behind the 5speed gearbox(60a), and will get it balanced at the same time at Hardy Spicer, $130+gst......
Posted on: 2003/6/24 13:23
From Melbourne, Australia
b120 beat me
but good point
fords are crap
is it worth balencing if you dont notice a vibration??
Posted on: 2003/6/24 13:25
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Millgrove Vic OZ
Yep, Sure is.
An out of balance drive shaft robs precious horsepower
As devildat says, it about power to weight and we need all the power we can get
Posted on: 2003/6/24 13:55
Cheers Feral
i said that when i was thinking he would be using the old shaft, with new i definatlely would want it
how would it rob horsepower though i dont understand that?? or are you just talking about a minimal amount
Posted on: 2003/6/24 13:57
1200 Coupe Rallycar
Out of balance forces create small amounts of extra drag internally in the box and diff unis ect. The main problem is is takes more power to accellerate the drive shaft if it has an pout of balance component (think of a piece of plasticine on the side of a length of rod and trying to accelerate this to 8000 rpm. A lot more effort is required to accellerate it if the engine has to overcome out of balance forces.
Posted on: 2003/6/24 14:03
Cheers Feral
Any vibration that can be removed from a 1200 is going to make it a more comfortable car. There is 30 more years of NVH science (Noise, Vibration and Harshness) in the new cars ... 1200s are quite uncomfortable over long distances because of all the vibrations.
Posted on: 2003/6/24 17:01
Re: Engine conversion day1,2....
From Brisbane
hehehe day 2 over no problems today the engine bay has been rubbed back to smooth, got any rust out and used rustkill and then primed tommorow is painting, cutting extractors then making a sleve for it, watch the paint dry (if the rain stays away ), and setup up engine, for engine bay entry
Posted on: 2003/6/25 13:35
From Melbourne AUS
cutting the exhuast from the extractors first would have solved all your day 1 problems? why didnt you do that since you were gonna cut and flange it anyway?
Posted on: 2003/6/26 7:26
« 1 (2) 3 »
