Front spring Dimensions+rates?
From Melbourne, Oz
What are the Dimensions of stock Coupe Front spring's?
And what's a good spring Rate for A powered sedan that may hopefully see the odd track day?
Pre'Thank's,
Connor.
Posted on: 2008/9/23 8:52
"I hav achieved wood"
Re: Front spring Dimensions+rates?
im using 175 lb srings on coilovers and happy with them... others using 200lb and happy with tracj days etc. id say go for 200lb.
not sur on stock diameter... should be same outside diameter as the ones you have now
unless you mean coil width
Posted on: 2008/9/23 13:28
From Adelaide
pritty sure stock they're 110mm and ~90lb
Posted on: 2008/9/24 5:36
XR6T 320rwkw
Stock 1200 Sedan
1200 Sedan, S/C a15
From Albury
We are on sticky road tyres and found 225 pound springs are good on road and for track work. Contact me if you need a part number for the springs. Don't forget your strut insert as good shocks are as important as springs.
Cheers
Bob
Posted on: 2008/9/24 6:50
From Sydney
150 - 175lbs for street duties with a comfort ride, 200-225lbs for street duties with a sports ride, 250 -275lbs for the track. If you are going down the coil over route, I would go with the 65mm ID springs as they seem to be the most common these days. [in Australia that is]
I run 63mm [2.5"] springs and find it a little hard at times to find the parts im after at a competitive price.
Posted on: 2008/9/24 7:41
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
From Melbourne, Oz
Thank's A'lot fella's!
Posted on: 2008/9/24 7:47
From Adelaide
Hey Bob, can you post it up also prices
Does any one know the spring rates for Lowered King springs?
Cheers
Posted on: 2008/9/24 14:17
XR6T 320rwkw
Stock 1200 Sedan
1200 Sedan, S/C a15
From Albury
Hi Rock
Go To repco pedders etc and get them to get KDFL57-225 king springs (lowered 1200 springs 225pound compression.Poundage can be varied by varying last number ). Can't remember price ($225 I Think).Remember to add good shocks into the equation to complement the springs.
Cheers
Bob
Posted on: 2008/9/24 22:18
hey beeny try these guys, more than reasonable i found compared to pedders, whiteline and king springs
Hypercoil
they have an aus distributer in WA... he was more than helpful.
Posted on: 2008/9/24 23:02
Good memory! I always have to look up details like this:
coil outer diameter 110mm (4.33 in)
Free length 338mm +- 10
Spring constant 1.26kg/mm (90.7 lb/in)
<-- wiki clicky, search for Springs
Posted on: 2008/9/25 3:15
