dattoman_1000 parts for sale
From Perth
I am having a shed cleanout and have some things to get rid of
So heres abit of a list
Don't be shy to ask for other stuff you might be suprised what I have
1. SC14 Toyota supercharger.
Just the unit with the pulley on the front. No brackets , mounts , manifold etc to fit A series. I never tried to make it fit after buying it from Lobster here in 2003
$200
2. T25G turbo off S13 SR20 Silvia
Good second hand unit. No shaft play or history of smoke
$200
3. Twin weber manifold suit oval port A series. GX cast in it. I believe these were made by or for JTS.
$200
4. 1200/120Y A series 4 speed gearboxes.
$100 each x 2
5. CA18ET SOHC turbo motor from S12 SIlvia import
Comes with 5 speed box and computer , loom etc. These use a T2 style Air Research Turbo. Also have CA20 inlet manifold that goes with it to put the TB at the front to allow intercooler use. I was told when I bought it that it had 42000 km on it
Never turned over or tried to start since I got it
$700
CA18ET
6. 1000 upper ball joints new. 1 pair available. Aftermarket units
Last time I bought some in about 97 from Nissan Genuine cause I couldn't get aftermarket they were about $125 each
$100 pair.
7. Chrome KB10 tail light surround. Unsure what side or even if they are different left to right.Brand NOS in Nissan box.
$50
8. Pair of 1000 4 dr sedan front doors. Good nick .. look ok and straight and rust free when I last looked at them. Will check again if someones interested .
$50 pair
9. 202-4203 ARP Head stud kit for A14-15 . A must when trying to boost a big A to keep the head squished down nice and tight
$100
10. A14/15 race engine. Specs can be supplied. Complete with roller rockers and many mods
Has made a lazy 98.7hp ATW with low comp pistons.
$5000
11. Celica T50 5 speed box suit A series. Comes with Dellow bellhousing kit , Toyota 200mm cushioned ceramic clutch and steel billet flywheel.
$1500
Would prefer to sell engine and box as a combo to keep engine balance right with the flywheel and clutch being balanced to engine .Will do engine/clutch box combo for $6000
Sounds alot but you won't build it for less.
12. EFI manifold for oval port A series
Modified "GX - JTS" manifold to take injectors. requires alittle tickle with the die grinder and a coat of silver paint to make pretty
Has injector rail and injectors. I was going to use it on the race motor in a street car with a single TB on the front and a plenum in a turbo application.
$350
Lots more stuff... big shed cleanout... don't be shy... ask.
Posted on: 2008/11/12 10:18
Re: dattoman_1000 parts for sale
From Sydney Australia
pm sent
Posted on: 2008/11/12 10:31
From Sydney
PM sent re: ARP head studs.
Posted on: 2008/11/12 10:32
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
From Melbourne vic
Pm sent
Posted on: 2008/11/12 10:52
:Impressive, will it fly?
:Yes, if i fold it here and here
:Nice
From Perth
So far some interest but no-ones shown me any cash loving
On hold...
ARP head studs
KB10 chrome tail light surround
1000 Upper balljoints
GX inlet manifold
I thought you guys would be all over some of these parts
Maybe no-one needs anything
Be a shame to lock it all up in storage while I'm away and not be used by someone else
Posted on: 2008/11/16 5:19
From Melbourne vic
pm sent
Posted on: 2008/11/16 5:24
:Nice
Not too shy to talk
where abouts are you located ?
interested in a 120Y box
Posted on: 2008/11/20 22:12
From Perth WA
Hes in Perth, Down Gosnells way unless hes moved.
Shoot him a PM
Posted on: 2008/11/20 22:32
Chris...
From Coondle, WA Australia
Mike, but everything he has for sale, so that these bits dont get lost into storage! I would consider it my self, but the lack of a shed, plus renovations, plus moving house has somewhat drained the accounts. You know you want to, particulaaly the injection setup.
edit : crap, I have just hit 1000 posts and it wasnt even something super intelligent. Damn. Here I was trying to impress others, and i failed. Oh well.... now to catch up with DD....
Posted on: 2008/11/21 10:51
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
From Freo
Heya Rubin.. here's an idea.. u buy stuff.. an I'll let you keep the gear in my shed... :)
Posted on: 2008/11/21 10:58
A15 PSI Project Motor
'72 CB750k,
