my A14 is STUFFED! what shall i do???????
From VIC, bendigo.
my A14 is bellowing out Blue smoke all over the shop! so i'm thinking rebuild, piston,rings, havn't pulled the head off yet, so dont quite know the situation.
just wondering what would a rebuild cost, piston,rings, ect, or is it it worth finding, another engine like A15 with mods???
Posted on: 2003/7/7 12:18
1200 Sedan.Turbo A14 drawthrough 15psi Meth inj 104rwkw
1200 coupe club car. turbo L20 drawtrough
Re: my A14 is STUFFED! what shall i do???????
From Warwick, QLD
Buy my A15, PLENTY of mods, PM me if interested
Cheers
Damo
Posted on: 2003/7/7 12:22
Drive It Like You Stole It
Every Car Has 500hp In The Wet
Team NEW SKOOL
Bluish/white smoke = burning oil.
It could be just the valve seals, which can be replaced without removing the head. This generally causes blue smoke when you first start the engine, then stop after a minute or so.
If it pours out smoke when you rev it, that's the rings. Do a compression test to verify. You generally do not need to replace the pistons, just hone the cylinder, replace the rings and of course the gaskets.
If it is smoking at idle, it's either really worn, or something is wrong (like too much oil in the engine). Do a compression check to double-check.
Posted on: 2003/7/7 19:34
First thing and most important is do a compression check.
Then a few conclusions may be drawn
Posted on: 2003/7/7 23:39
From Sydney
wake a CA18DET in it....
Cheers
Peddler
Posted on: 2003/7/8 1:09
Quite a regular
From Sydney, Australia
I think I have a nice warm fully rebuilt A14 that I might sell.Oversize piston's, cam, head work, built by JTS.
john@motorsportonline.com.au
Posted on: 2003/7/8 1:15
Boston Racing
From VIC, bendigo.
ok, so it blows blue smoke out on idle, and still bellows out when driving, comp: is 170 on all except for number 2, it has 120.
might invest in new engine.
Posted on: 2003/7/8 2:33
From Sydney
From what i have been reading........sounds like the problems lies with cylinder #2......more than likely the rings on this cylinder are no longer sealing...................i dont think this warrants investing a whole new engine.......just a rebuild of the one you have. Depending on the condition of the pistons, you may be able to get away with honing the bores and fitting new rings. It all depends how far you go......do you replace the friction bearing while the engine is apart etc etc.
Engine parts for the mighty A-series are relatively inexpensive.
Benny
Posted on: 2003/7/8 3:18
trickdat, test #2 again, then squirt a couple squirts of clean engine oil in the spark plug hole, and test it again. If it jumps up close to 170 lbs, it's the rings.
Posted on: 2003/7/8 5:16
