5 speed gearbox on a A12 motor ?
hey guys im thinking of putting a 5 spd gearbox in my 1200 gx . Im not sure if it would be a wise move but it def. needs a 5th gear... so if any of u guys have some knowledge to share it would be much appreciated.
Posted on: 2008/12/1 9:53
Re: 5 speed gearbox on a A12 motor ?
From Darwin NT
should be a straight bolt in almost unless its hydrualic clutch then a bit of work will be needed
and also might need an adaptor for the gearbox mount
Posted on: 2008/12/1 10:06
current project 4x4 patrol...
From Sri Lanka
Hi Bin
I also thought so,Changing into 5 Gearbox, How much of a mileage your one gives now ? My one is about 10 in city and 12 in long, would the conversion improve that and supportability. Any suggestion ??
Thanks
regards
Posted on: 2008/12/1 10:10
Changing to a 5-speed will not improve city economy much if any. It will change high-speed economy for the better. You should be able to go from about 30 miles/gallon highway to 35 mpg or thereabouts.
Datsun B210 with 5-speed (single carburetor model) got up to 50 mpg in USA specification with 5-speed, but only 40 with 4-speed.
A14 engine!
Posted on: 2008/12/9 8:41
From malta
i ve done that it is a str8 bolt on. my clutch is cable. on high speed the engine will rev less so you will be doing 60 - 70 mph
when the engine is at 1500-1700rpm.
remeber the reverse is instead of the first
the first is at the place where normaly the second is
the second is where normaly the third is etc etc.
the gear ratios are slightly different. and aceleration will be a littlebit different.
Posted on: 2008/12/9 11:41
From Pune City, Maharashtra State
Dear Bin-Boy & Sumith,
I am Ilango from India. I have a Premier 118NE, which is Fiat124 with a Nissan A12 power train. I always had dream of having an overdrive. Could you please help me out with any leads on a 5 speed 60 series RWD transmission?
I am fine with importing it to India.
Thanks in advance.
-Ilango
Posted on: 2012/7/9 19:49
$450 gearbox + $450 shipping overseas?
Posted on: 2012/7/9 20:16
Clearly thats a $USD quote.
Posted on: 2012/7/9 21:42
Fiat 124 with A series engine please any pictures?
You are lucky with that car that you can run much bigger diameter tyres than we can, have you tried that first? eg. 185/80 series 14inch in good road conditions or 185LT R14 lite truck tyres for nasty road surfaces.
Posted on: 2012/7/10 0:18
Premier 118NE
Posted on: 2012/7/10 0:52
