Datsun B210 Or B210 GX ??
From Sri Lanka
Hi Guys,
Can any one tell me how to identify, Datsun B210 Or B210GX engine By external or internal view of the engine
Thanks
Regards
Sumith
Posted on: 2008/12/11 3:43
Re: Datsun B210 Or B210 GX ??
From Perth WA
the most obvious giveaway to the untrained eye will be twin carbs on a gx, vs single on standard motor.
Posted on: 2008/12/11 5:02
From sydney australia
There are a couple of things to look for if there are no carburettors on the motor. Remove the rocker cover & check for twin valve springs, & while you have the rocker cover in hand, check if the little spring clip for the throttle cable is in the centre of the rocker cover, going from front to back. If these are present,it's a good chance it's a GX. If it's single valve springs & the spring clip is towards the rear of the rocker cover,it's more than likely a standard engine.
Posted on: 2008/12/11 23:28
Millions of B210 GX cars came with a single carb engine, no dual valve springs.
Sumit, what are you trying to identify? If a specific engine came from a B210 instead of some other Datsun? Or if it is a twin-carb engine?
Posted on: 2008/12/12 0:38
From Selangor, Malaysia
hi guys,i'm using a b210GX..at malaysia the different is only at the back lamp
yet nothing different about the engines..its using a single carb and no dual valve spring
Posted on: 2008/12/12 2:13
