(1) 2 3 4 »
pros and cons of methanol
Quite a regular
hey lads its me again been a bit a busy so i put the ca plans on hold for a while but hopefully after chrissy i can pick up the block and start just a reminder as to what im doing a nirous prepped ca 18 to run through a c4 and i had an idea to run it on methanol for sumthing different just wanted to know the pros and cons of methanol?
Posted on: 2008/12/18 2:29
Re: pros and cons of methanol
Con: half the power of gasoline, so you need twice as big a tank to go the same distance. Also it is corrosive to alluminium
Pro: You can make it at home
Posted on: 2008/12/18 2:35
From Rosewood, QLD
methanol or ethanol?
Posted on: 2008/12/18 2:37
1971 B110 sedan project.
2012 Nissan Micra daily.
Quite a regular
lol then what is the benefit? arent u supposed to get more power? (excuse my naivity but im still 18 lol hey gotta learn)
Posted on: 2008/12/18 2:40
From perth airport
burns cooler ? at a guess
Posted on: 2008/12/18 3:00
perth airport parking
Datsun 1200 ute A14
From Melbourne vic
little advantage for the street and probably
illegal in all states anyway. It's a racing fuel
Posted on: 2008/12/18 3:03
:Impressive, will it fly?
:Yes, if i fold it here and here
:Nice
From Perth WA
C4 .. Ford tranny? or is that an ecu?
Posted on: 2008/12/18 4:10
Yes, it is used in many racing series (e.g. Indy 500) because if it catches fire, it can be put out with water, plus there is no smoke to cloud up the race track.
Posted on: 2008/12/18 4:24
From South Africa
methanol is much safer than fuel, in an event of a fire, as it can be put out with water.
Methanol has a much higher octane rating than your average petroleum fuel.
Methanol does not deliver as much energy per mass, as fuel.... BUT
and this is why Methanol is so potent....
It brings it's own booz to the party.... or otherwisely stated, it brings along a couple of it's own O2 molecules. so you can fit a hell of a lot more methanol\ air mixture through the same hole in the same time... giving you a much bigger bang.
it's toxic to the touch, i.e. your skin absorbs it.... not good.
it collect water vapor from thin air, so after time it's useless.
it's cheaper than fuel....
Posted on: 2008/12/18 4:30
From Melbourne vic
methanol is safer because it is less volatile
than pump fuel and doesn't "explode"
Posted on: 2008/12/18 4:33
:Nice
(1) 2 3 4 »
