Browsing this Thread:   6 Anonymous Users
Tunnel mount removal?
From Wagga Wagga, NSW
G'day lads Just wondering how you've gone about revmoving the standard a-series gearbox crossmember mounts that are spot welded into the tunnel with out damaging the tunnel? its got me confused.
Cheers Jake
Posted on: 2008/12/20 23:12
Re: Tunnel mount removal?
I haven't done this on the tunnel mounts, but generally you would drill out the spots welds, the part falls off, then you plug or weld the holes.
Need room for a CA tranmission?
Posted on: 2008/12/20 23:27
From Armidale N.S.W
NO Don't drill them right out. There is a special spot weld removal drill bit ( Learnt from Laney). Go to Mitre 10 or a decent Hardware they will have them. Grab a wire wheel or coarse sand paper sand around the mounts so you expose the spot welds a bit better and then carefully drill with the bit it will leave little lumps and you can file or coarse sand them down smooth. The last thing i would want is more damn holes in the body and floor they are thin enough.
Posted on: 2008/12/21 0:52
73 1200 wagon SOLD
From Townsville, Qld
Yeah I should have done that, I use to drill through them and use an antique wood chisel to tear them off. That went down real well with dad...
Posted on: 2008/12/21 1:04
From The garage, NZ
jack hammer...
Posted on: 2008/12/21 2:21
Thanks fellas ill see how I go....EEEEEEEPPP
Chris-your on a negative down spiral lad!
Posted on: 2008/12/21 2:58
From cranbourne, vic
+1 for the insanely priced spot weld drill bit
Posted on: 2008/12/21 7:34
82 1200 ute - daily
89 R31 H.M.A.S. Skyliner - drifter
197? 1200 coupe - new drift project.
85 CMA81 nissan/ud 9.5ton banana back - tow pig for the drifter.
From Tamworth , NSW
ill definetly second the spot weld bit.
and ill second the rediculous price too.
Posted on: 2008/12/21 8:12
From The garage, NZ
jake - you are a retard, lad
Posted on: 2008/12/21 8:40
From Christchurch NZ
I tried to use a spot weld drill, and found the angle meant I couldn't get them. So I ground, and cold chisled them off and made a hell of a mess.
Posted on: 2008/12/21 9:47
Forced Induction!
