sr20 in 1200 ute with trust wing'd sump ?
From perth airport
any one done it is there room ?
with maddat fitting kit
Posted on: 2009/1/20 2:22
perth airport parking
Datsun 1200 ute A14
Re: sr20 in 1200 ute with trust wing'd sump ?
From SE Melbourne
From my experience (with a winged sump in the CA) - the sway bar is the clearance issue - it doesn't seem to get in the way of much else.
Posted on: 2009/1/20 7:08
Mildman, Datsunless
From perth airport
time will tell :)
Posted on: 2009/1/20 21:20
Datsun 1200 ute A14
From Christchurch
Yeah I had planned on running one, I was just going to get a swaybar custom made to clear the sump. I'm not up to that stage yet but i don't really see it being a problem
Posted on: 2009/1/20 21:46
From perth
TIG
Posted on: 2009/1/21 9:59
From perth airport
you mean kustom make a wing'd sump there dazza ,
coz i have a genuine trust wing'd sump allready ( left over from drift car )
if they 100% dont fit i might sell it coz they worth big bucks
Posted on: 2009/1/21 10:48
Datsun 1200 ute A14
From Adelaide
I dont think they will fit, i havent tryed, but have measured one up and they are just too wide.
You would have to make a very wide sway bar and up size the diameter to compensate for the extra length, and it may get very close to you front radius rod mounting points.
Posted on: 2009/1/21 11:05
From Mandurah, Western Australia
Given what a genuine Trust unit would be worth, you could sell it, Fabricate a new one and get a custom sway bar made. And maybe have some $$$ left over.
Posted on: 2009/1/21 13:37
From perth airport
yep :) and i scored a big whiteline sway bar last light for the ute :) hope it clears the sr
Posted on: 2009/1/21 20:49
Datsun 1200 ute A14
From Christchurch
I can't afford a trust opne, I'm just going to get a cheapy chinese copy off trademe. My sr also sits back about 50-75mm behind firewall so I guess that should give me a bit more room for the sway bar.
Posted on: 2009/1/21 20:52
