MSD or Fireball kits? views?
From Brisbane
I am real keen to install a fireball kit into my ute, they are pretty much same as MSD kit but bit different though, i was wondering what peoples views are on these kits? anyone got a fireball kit? i have been told best thing since sliced bread for dattos
p.s if ya dont know bout the fireball kit check it out : http://www.cranecams.com/FireBall.htm
Posted on: 2003/7/31 10:46
OLD SkOOL POWeR!!! [color=CC0000]"with the sound & smell of twin 40s at full throttle!!!" [/
Re: MSD or Fireball kits? views?
From Okinawa, Japan
All I can tell you is my MSD really woke my A12 up. But we've already discussed this on MSN huh... don't know much about the fireballs.
Posted on: 2003/7/31 10:51
So MSD 6a boxes work? cool , I got a MSD 6a , billet MSD distributor ,Accel super coil, Weber 32/36 and headers 6 into 2(right, 6 into 2, it is for my super RHD postal jeep, my Datsun cars' best friend), I got it a while ago and I will pepe up the 6 in line banger to make it mor reliable, it's my towing car, and beach/ rough terrain buddy. Should I expect a much better response with all that installed? I hope, it was not cheap, and the next one will be the A15, MSD 6A box, recurved distributor,headers, after that, cam and twin DCOE's.
Jaime____________________________
Posted on: 2003/8/1 5:09
From NorCalifornia, up by Sac
Jaime........a MAJOR word of warning about towing with a Jeep.......DON'T!! I have seen what happens when such a short wheelbase tow vehicle gets up to speed. The jeep went fishy & rolled. Permanent end of story. Just keep it on surface streets & under 50mph if you tow. Please.
Posted on: 2003/8/1 5:29
A right hand drive Jeep......now THAT'S cool! Just be careful. Damn, I sound like my parents.
Posted on: 2003/8/1 5:31
Yes, RHD jeep, I will post a picture , it is cool, powerfull and cheap. When I tow, it is short distances, and with a tow bar, it has plenty of power, but the short base makes it not perfect for towing, but , short distances is fine, the short base makes it prone to understeer while towing, but with care, no problems at all. If not towing, it is a fast conmuter, goes fast in highways, excelent for long distance driving, I took care of the stability issues of jeeps with wider tires/wheels, it drives like a train, most important, I would never go beyond its capabilities, as a driver, I got to respect the capabilities and limitations of any car I'm in .
I'll post a picture, not a Datsun, but my Datsuns' best friend!!!!!! Jaime
Posted on: 2003/8/1 5:48
From Castro Valley,CA USA
I have an MSD 6AL. It's the same as the 6A with a rev limiter. That's the main reason I got it. Works just fine. I had some problems at first. The hotter spark would "leak" through my cheap spark plug wires.
I also use a Pertronx Ignitor in the distributor to trigger the MSD. Pertronix Ignitor
Posted on: 2003/8/1 8:59
From Okinawa, Japan
Hey ang... what did you open you plug gaps to?
Posted on: 2003/8/1 9:12
Petronix ignitor, that is what I will need for my L20B, points dist, the A15 has electronic dist, but the L20 will get the Petronix, treatment, is it work oK?
I posted some pixes of the MSD box and distributor.
Cheers___________________________
Posted on: 2003/8/2 0:26
I think the plug gaps are .055"(1.4mm).
The Pertronix works fine. It mounts in place of the points and a small plastic piece with the magnets slips on the dist shaft under the rotor. The blk wire goes to the coil(-), the red wire goes to +12v at the balast resistor. That's it. I use to carry a new set of points in the car just in case it failed.
You can NOT use a high power coil with the Pertronix, they pull to much current and can burn it up(that's what the instructions say).
I didn't notice any major change in my car's performance but I've also never had to change or adjust **cking points again.
I believe it's also a legal upgrade in some race catagories.
Posted on: 2003/8/2 9:01
