A15 industrial engine EFI
Quite a regular
Hey just looking for A15 hp figures, stumbled across this.
It is a concrete pump using an a15 engine with efi that has a single injector at the throttle body.
http://www.justanswer.com/questions/1 ... san-a15-industrial-engine
http://findarticles.com/p/articles/mi_m0FZX/is_1_70/ai_112686562
Alternate EFI manifold anyone?
Posted on: 2009/3/8 23:25
Re: A15 industrial engine EFI
Ah, Zenith ZEEMs off-road EFI. It's a good system, about the size of the original carburetor and runs at four different speeds.
Posted on: 2009/3/9 0:12
Quite a regular
I wonder how it would handle 15psi or so
Posted on: 2009/3/9 11:25
From Sydney, Australia
I would consider retrofitting one of these to my stocker.
You could hide it under the stock air filter maybe?
Posted on: 2009/3/9 11:56
It has fly-by-wire-throttle. Or in other words, no throttle cable.
Posted on: 2009/3/9 16:34
The 4 fixed rev speeds is probably only good for pumping or other industrial appsthough. I wonder if any one knows of a tbi system that would work on a datto on such a way that it can be hiddn. I'd like the reliability without the bling.
Posted on: 2009/3/9 20:22
From hastings,vic
u could try camira tbi
Posted on: 2009/3/10 8:05
taking up room at home
hzj75 cruzer tray(for sale)
and allways changing
Quite a regular
It might be as simple as re-routing the circuit of the controller to a simple variable resistor mounted on a shaft with the standard carbie's throttle wheel and a spring.
Im sure you could knock that up for under $10 with a trip to dick smiths / tandy / radio shack.
2 hour job??
Would be a laugh if it worked, they claim a lot about the fuel efficiency / emissions with that zeems setup... good for a daily driver...
Posted on: 2009/3/10 13:12
From Toowoomba, Qld
EA falcon tbi might be easy to adapt as well, the tb should bolt onto a dgav adapter. Not sure what else is in the system to make it run though.
Posted on: 2009/3/10 13:19
