Help..Fire!!
From Selangor, Malaysia
Hi guys,
need ur help and expertise here..
just installed Solex 40 to my a14..but i'm facing 2 problems which is giving me a headache :-
1. Backfire in the carb
2. Only 3piston running when idle
when i change back to the old carb (downdraft) ..it all went well..nothing wrong..
what caused the problem?
thanks.
amin
Posted on: 2009/3/10 4:28
Re: Help..Fire!!
From campbelltown (sydney) australia
what u mean 3 pistons running at idle, if a piston wasnt moving then changing the carb wouldnt make it go again, sounds like broken piston/rod/gudgeon pin ......
Posted on: 2009/3/10 5:10
* caution, sunglasses must be worn to view my ca18det *
Re: Help..Fire!!
From Darwin NT
i think what he means is that it was down 1 cyl or in other words 1 wasnt firing
Posted on: 2009/3/10 5:12
current project 4x4 patrol...
Re: Help..Fire!!
From Perth WA
du u mean twin 40's ?
1 throat/jet not working, blocked would explain 1 cyl not firing on idle, the main jets work but not idle jet on that throat.
backfires if u havent changed anything else might be its over jetted if u havent got cam, exhaust, ignition to cope with the extra fuel.
Posted on: 2009/3/10 5:20
Re: Help..Fire!!
1. Remove all air filter bases and horns. Test it like this before putting air filter back on. Mine had the wrong base on it, caused really bad performance and backfiring. I could still do 120 kph though.
2. Make sure the Starters (chokes) are rotated all the way -- they can cause weird coughing and backfiring if out of sync with each other.
Posted on: 2009/3/10 5:46
Re: Help..Fire!!
i'm using twin 40's..
1 wasnt firing..it only firing at hi rpm,but still have the backfires..
neway thanks for the advices..
will recheck the carbies again
thanks you very much
Posted on: 2009/3/10 5:56
Re: Help..Fire!!
From Sydney
backfire indicates a lean mixture condition. I would also be checking the idle cct for the cylinder that is not firing. No fuel = not firing. I would also check the balance between the twin carbs, i.e are all 4 throttle plates opening in a synchronis way. And lastly, see if the progression holes are blocked or not, this can also induce a lean mixture.
Posted on: 2009/3/10 6:31
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
