curb weight 120Y
From Toowoomba, Qld
Anyone know the curb weight of the 120Y's offhand?
Posted on: 2009/3/20 6:31
Re: curb weight 120Y
From Canberra
I dont know what kerb weight is, but mine was 1060kg on the weighbridge with me in it.
Posted on: 2009/3/20 6:38
GVM is supposed to be 850kg in standard trim. Mine weighs a bit more though. I should get it checked.
Posted on: 2009/3/20 6:49
From Toowoomba, Qld
thanks guys.
Is there much difference between sedan and wagon?
Posted on: 2009/3/20 6:50
From Sydney
my sedans got 820kg on the rego papers
Posted on: 2009/3/20 10:58
From Ipswich, QLD
Here you go
1974 Datsun 120y B210
Wheelbase 2340 mm 92.1 in
Track front 1260 mm 49.6 in
Track rear 1255 mm 49.4 in R31 skyline is 1410mm
Length 3950 mm 155.5 in
Width 1545 mm 60.8 in
Height 1370 mm 53.9 in
Kerb 810 kg 1786 lb
Hope this helps
Posted on: 2009/3/20 11:38
From Toowoomba, Qld
Thanks for the info guys.
Dave
Posted on: 2009/3/20 11:48
You will find the actual weight considerably more than the "registration" weight.
Posted on: 2009/3/20 17:38
From Toowoomba, Qld
I figured as much, and Tyrie confirmed it.
Gotta add at least 75Kg for driver as well in my case.
Posted on: 2009/3/20 20:23
From Townsville, Qld
I went over a wieght bridge at teh dump a couple of years ago with a near empty tank, probly had spare tyre, 10kg of used oil and 58kg of me. I came in at 940
Posted on: 2009/3/20 21:53
