Hi newbe
Hi all,
Im lionel .Iv register as iv under taken a b120 and im looking for info as im going to put a SR20det in to it. I trying to find out what gear box will fit also engine mounts etc.
If anymore can help that would rock
Thanks Lionel.
Posted on: 2009/3/24 21:19
Re: Hi newbe
hi newbie, try the search function....
Posted on: 2009/3/24 22:03
Re: Hi newbe
Hi LB,
Welcome to the club
Posted on: 2009/3/27 1:55
Re: Hi newbe
From pooraka,,adelaide
Hi and welcome
My m8 is doing a sr bluebird and he is using an rb box
Posted on: 2009/3/27 5:23
620 ute -sr20det full irs
vanette-a15 turb
260c- daily
1000 4dr- a15
1000 4dr- project to be sr20
garage 910
Re: Hi newbe
From Geelong, Vic
whats wrong with the SR box?
Posted on: 2009/3/27 5:43
Re: Hi newbe
From South Africa
For a stock SR20 they are fine, in fact up to about 300kw they are ok, after 300kw they fall apart fast, I have loads of them in the scrap metal pile, most common problem is they shear all the teeth of 3rd, bend layshafts, split casings, snap input shafts, snap output shafts ectr... whole box pretty much becomes rubbish over 300kw (and thats on street tires not slicks)
RB box on the SR20 motor is the way to go if you want good reliability.
Posted on: 2009/3/27 13:37
Re: Hi newbe
hi guys
thanks for the welcome. im trying to find info out about fitting the box from a sr in to this car just need to know if the tunner need cuttig etc ?
Posted on: 2009/3/28 9:39
Re: Hi newbe
There is a discussion about fitting an SR to a 1200, not sure if it has any answers about the gearbox question, but you can read it: SR engine swap. Add what you know to the article.
Posted on: 2009/3/28 16:50
