Radiator Fluid Level reducction ratio
From Sri Lanka
Hi Guys,
What is the Usual ratio of radiator fluid level reduction ?
EX:If u drive 20 Km in normal drive , what would be the reduction of water in the radiator (usualy how much will have to put in to fill the radiator ?
By your guys experiment post me please
Thanks
Regards
Sumith
Posted on: 2009/4/2 10:39
Re: Radiator Fluid Level reducction ratio
From gold coast QLD.
None,unless you have a problem
Posted on: 2009/4/2 10:44
it should have a gap from the neck of the rad by about 1 inch, but the coolant should still be above the fins of the top tank by about 1 inch as well.
There will be a small pocket of air at the top of the rad.
Posted on: 2009/4/2 10:51
From Sri Lanka
Hi Guys
To be frank with you , i don't have any coolant setup in mine, i have an idea to fix a setup , any one give me a clear idea how that can be done , what would be needed ? if there are pictures that is much better ..
Thanks
Regards
sumith
Posted on: 2009/4/2 11:04
From South Africa
Any idea why the A-series like to blow out the coolant till it has a 15-20mm air pocket in the radiator? it always worries me a bit especialy when im racing. I am running a 1.1bar cap on an aftermarket S13 radiator and it still will blow out about 200ml of coolant if i top it up (in hope to let it cycle coolant in and out of the coolant catch tank I build)
Posted on: 2009/4/2 11:57
'75 1200 B110 - 154hp Race prep A14
'97 Silvia - 600hp SR20 time attack
'07 Hilux - Tow car
yeah you need the coolant catch tank withthe s13 set up, it has a recovery style cooling system on the rad cap. needs to pull and push coolant in and out as required.
Posted on: 2009/4/3 3:28
From Perth WA
its not just a series that do it, any engine that runs fairly hot does it too. the coolant expands as it heats up and has to go to overflow, shrinks when it cools and draws back into the rad.
Posted on: 2009/4/3 3:46
Yes, Bert is correct: "None,unless you have a problem". I haven't added water to my Datsun 1200 in over six months and the level is still correct.
And Yes, the Datsun 1200 owner's manual says to fill the radiator only to "1 inch below the filler neck".
Posted on: 2009/4/3 4:32
From Sri Lanka
Hi Guys,
I don't see any water leak from my radiator , but my water level reduces, but most of the time my heater gauge also running in the mid range , so what would be the reason guys ?
Thanks
Regards
Sumith
Posted on: 2009/4/3 4:40
From Perth WA
u had a new head gasket not long ago, isnt it? temp in the midrange is ok, so u must have a leak somewhere, check all your hoses and clamps.
Posted on: 2009/4/3 5:17
