Problem with Parkers
From Armidale N.S.W
Anyone ever experienced problems in there 1200 with Headlights coming on when you pull the headlight switch on for Parker's ? We thought we had it solved but its come back again, Help Please
Posted on: 2009/4/11 6:00
73 1200 wagon SOLD
Re: Problem with Parkers
From South Africa
My 1200 does the same thing, never bothered to check it out yet, maybe a faulty switch?
Posted on: 2009/4/11 6:51
'75 1200 B110 - 154hp Race prep A14
'97 Silvia - 600hp SR20 time attack
'07 Hilux - Tow car
First click with the highbeam on will give you just park lights, second click with highbeam on will give you highbeam. Highbeam off, lights in both positions will be on dip.
Posted on: 2009/4/11 7:32
To do something well is so worthwhile that to die trying to do it better cannot be foolhardy. It would be a waste of life to do nothing with ones ability, for I feel that life is measured in achievement, not in years alone.... Bruce McLaren
From Armidale N.S.W
Thanks problem solved. Will educate the mechanic on that one he told me different or i herd different
Posted on: 2009/4/11 8:51
73 1200 wagon SOLD
From illawarra, nsw australia
yes i went frantic trying to solve the problem before rego
turns out its a datsun thing
Posted on: 2009/4/11 9:38
From sydney australia
I think it's an early attempt at headlight flashers,like you get now.
Posted on: 2009/4/13 2:21
From Bris Qld Jimboomba
Hey guys, I have just put all my car back together and my lights do the same headlights with parkers, all lights work fine apart from this, tried the solution that was mentioned did not change any ideas as I am trying to get it registered soon, any help thanks.
Posted on: 2009/4/15 11:02
From Armidale N.S.W
If you have them on high beam before and during pulling the switch on only parkers will come on on first click then high beams on second click. Both will be on on both clicks on low beam. If no joy check all your earths that was my problem originally and crappy old fuses.
Posted on: 2009/4/15 12:25
73 1200 wagon SOLD
This is why it is valuable to obtain an owner's manual for your 1200 -- it explains how these things work.
Datsun 1200 had a headlight flasher option, so it's not clear why the Aussie 1200s work that way. Less expensive than the option perhaps.
Passing Light Switch
Posted on: 2009/4/15 20:48
