120y coupe going too fast
From Brisbane, Australia
Hi, was wondering if anyone had any ideas as to why my 120y coupe is reading slower than what I'm actually going. It reads 80km/h when the gps tells me I'm doing about 100 km/h. Was thinking it could maybe be a seepdo cable issue. It has a A14 with 56a 4speed in it.
Thanks Geoff.
Posted on: 2009/4/10 22:56
Re: 120y coupe going too fast
From Toowoomba, Qld
What size rims and what profile tyres are you running.
That can also have an effect on speedo reading.
Posted on: 2009/4/10 23:18
Stock 12 inch standard profile tyres.
Thanks
Posted on: 2009/4/10 23:30
From Toowoomba, Qld
does the needle move smoothly from slow all the way to fast or does it 'flick' around?
if it flicks a bit it's likely the cable. If it's smooth, its likely the guage.
Posted on: 2009/4/10 23:37
The needle is smooth in motion, just doestn't read correctly. Is about 20km/h out gets further out the faster you go.
Posted on: 2009/4/11 1:32
The gearbox probably was originally in a 13" tyre vehicle.
You just need to get a different gear for the end of the speedo cable thing that goes into the gearbox.
Posted on: 2009/4/11 3:25
Thanks mate, I was thinking it would be something like that.
Posted on: 2009/4/11 4:54
From northern 'burbs adelaide
the original calibration would have been for 12" cross ply tyres which are bigger in diameter then the modern 12" radials ... a set of 13's with like 70 profile tyres will fix it all up
Posted on: 2009/4/11 15:17
From Townsville, Qld
Man a 120y can never go too fast :P....
Posted on: 2009/4/12 9:59
Yes, no 120Y has ever gone too fast.
Here's my 1200 speedometer:
Reads: 35
Actual: 29
Posted on: 2009/4/12 20:55
