hitachi twin carbs help
Not too shy to talk
From Drouin, Vic
where on these flat top hitachi carbs is the stupid part number? ordering a carby kit and need to check the carby model. does anybody know what to do about worn jets? just keep using them or is there something still available that can be fitted? cheers. they arent running too well so think it's time to clean and renew.
Posted on: 2009/4/22 12:01
Re: hitachi twin carbs help
From Darwin NT
not sure about needles but heres the carb kits
carb kits
also check out the wiki i done a tech section on these carbs
Posted on: 2009/4/22 12:07
current project 4x4 patrol...
Quite a regular
From pretoria, south africa
rather go to a carb shop and just ask for the hitachi for the 1200gx and they`ll get it for you its better there cause anything from nissan is way over priced.. they give you needles for the 1200 and 1600
Posted on: 2009/4/22 19:38
The part number is printed (not stamped) on the Hitachi carburetors. Often they have been rubbed off, or just faded away. But many 35 year old Hitachis still have the number visible.
It is on the flat at the top of the carb body (just below the tops).
See the Tech wiki for identification clues: Hitachi Twin Carb
* Flat top is 1974 or newer
* Four-bolt types are 1976 or newer
* Are yours 38mm or 46mm bore?
Posted on: 2009/4/22 20:44
From sydney australia
Fabre Australia here in Sydney have parts for the Hitachi carbs, plus they can supply needles to suit. I always go for the GR needles, they seem to work better than the stock ones. They only work Monday to Friday, which makes it hard to pop in on Saturday mornings.
Posted on: 2009/4/22 22:55
