Browsing this Thread:   3 Anonymous Users
« 1 2 (3) 4 »
Re: A-series Intake and carb showdown
did u have any pic of the ...weber manifold
Read all about the Twin Weber car here: Ernie's Twin-Weber Downdraft
Posted on: 2009/4/21 17:50
Is it possible to get a picture with the camera 'in' the engine bay, approximately at the height of hte centreline (throttle shaft ) of the carbs looking back toward the firewall. It's hard to tell from the picture (and I've looked at a couple of others I have of rhd 1200s with webers but none have the right angle to 'tell') but how high is the master cylinder - will the carbs collide with the master cylinder itself, or with the reservoirs?? If it's the latter, some remote mount reservoirs are surely an option.
How about a combination of that, and a cut n shut re-weld/tweak of the inlet manifold to make the carbs very slightly downdraught, or with a _very_ subtle S bend to get more height??
I'd go even further - if (via a combo of the above stuff) you get them to fit, you could run 90 degree bends as the 'trumpets' and then have them radius out and all sit within a common air filter/plenum arrangement. perhaps not 100% ideal, but since the 90 degree bend would be dry air, not fuel suspended therein, it shouldn't be near as detrimental as it might otherwise seem)
Obviously I stink at mspaint, but you get the idea. It needed be a big oval plenum or air filter - perhaps a pair of oval ones - afaik they are available at approx the right dimensions to fit a dcoe weber or the like - you'd just be making a custom base plate with the 90 degree curves to mate it together.
It might even be of advantage - on a streeter, it effectively lengthens the runner length (a little bit at any rate) and likely the a-series could do with that - i.e. a runner length closer to what it would need for it's likely working rpm range.
Posted on: 2009/4/22 21:21
John McKenzie
From Freo
I've seen a twin down draft manifold in Japan, for webers looks a treat, I'd have one Just coz...
Posted on: 2009/4/23 1:06
A15 PSI Project Motor
'72 CB750k,
From Sydney
Mike, Were you referring to these? twin IDF webers on manifold to suit A series. In many ways the IDF weber carbs are a short version of the IDA Weber.
Posted on: 2009/4/23 2:29
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
From Freo
hell yea, that's them, I'd have them just because their different, but thats me.. ha ha
Posted on: 2009/4/23 3:01
'72 CB750k,
From Sydney
I have a twin DCNF manifold off a triumph spitfire at home and it is very very similar to the one pictured for the IDF carbs. I reckon with a bit of talented machining, it could be modified to suit the A-series cylinder head. I should post up a pic of it....
Posted on: 2009/4/23 5:04
1970 KB10 Coupe
S13 caliper b...
Na, dual sidedraft webers won't fit an LHD 1200 -- even without the bells they hit the brake master cylinder body.
There is a pic in the Tech wiki (under carbuetors) with an angle manifold dual-weber setup. These are not angled up, but angled forward.
Posted on: 2009/4/23 6:36
From Sydney
DD, you mean these bad boys..
Posted on: 2009/4/23 7:36
1970 KB10 Coupe
S13 caliper b...
From Los Angeles,CA
I've got a Wilwood pedal box that mount the Master cylinders facing backward under the dash. They're really small and can fit with a little rearranging under the dash. Then the reservoirs are remotely mounted on the firewall.
Posted on: 2009/4/23 7:59
on the other hand you can use a van setup or an early suzuki fronte hatch one.
All good but the wilwood stuff is top notch.
Posted on: 2009/4/23 9:29
« 1 2 (3) 4 »
