« 1 2 (3) 4 5 »
Re: Fibreglass coupe vents group buy
From windsor, sydney
thanks mate, can't wait to hear from you. wards
Posted on: 2009/4/26 10:14
From Adelaide, South Australia
Pm Sent
Posted on: 2009/4/26 10:30
From Seattle ,WA.
I'd like a set as well either your next batch or if someone bails. Let me know what you need me to do.
thanks, Evan
Posted on: 2009/4/26 12:23
From hastings,vic
thanks geoff i await your pm
tommo
Posted on: 2009/4/26 14:18
taking up room at home
hzj75 cruzer tray(for sale)
and allways changing
cant wait want to try my paint out on a white base
Posted on: 2009/4/27 10:08
Car free
pm sent
Posted on: 2009/4/28 11:17
Car free
From canberra
PM sent thanks
Posted on: 2009/4/28 11:45
need to move your ride
tuggeranong towing call 0421towing
0421869464
From Sydney
put me down for 2 sets please.
Posted on: 2009/4/28 11:49
From Ipswich,QLD
Ok >
datster . tommo73 . superfatto . all have pm
Ive replied to all pm recieved ....
The list is getting longer its gone from 10 to 20 so far .So it looks like its coupe vents week at the factory .cheers geoff
Posted on: 2009/4/28 12:14
From Ipswich,QLD
hi everbody Ive been working a fair bit on the coupe vents its been good ,Ive sent off a few sets ...
Preparing your coupevents to paint > I recomend rubbing them down with 240 dry sandpaper then 320dry sandpaper..
Make sure you dont leave no shinny bits ..Use a primer filler acrylic should be ok unless your painting them in 2pak..........
Ok when you drill the holes use a small drill bit and drill a pilot hole .......You will need to drill this hole the same size as the screw youre goin to use .......
Use a larger drill bit to counter sink the holes a little bit ....Make sure you have the vent on a somthing flat to support it when drilling .........this only a guide ,cheers geoff
Posted on: 2009/5/18 8:05
« 1 2 (3) 4 5 »
