Browsing this Thread:   8 Anonymous Users
Remove steering wheel Boss?
Any ideas how to remove this steering wheel boss?
Yes, I removed the center nut.
The problem is the bolt holes are teeny so I can't use my steering wheel puller with it.
momo boss (solid aluminum)
Posted on: 2009/5/4 5:17
Re: Remove steering wheel Boss?
From perth airport
put the steering wheel back one and hit with your hand working your way side to side up n down
if its realy on tight i have lost my cool and held it with both hands and through my body back n fro it works but can bend the steering wheel
Posted on: 2009/5/4 5:33
perth airport parking
Datsun 1200 ute A14
From newcastle, NSW
If you do that be sure not to smack yourself in the head with the steering wheel! lol!
Posted on: 2009/5/4 5:38
From Los Angeles,CA
This has worked for me... Put the wheel back on, leave the nut on but loosen it all the way to the end ( to keep the wheel from smacking you in the face if and when it comes off!) then whack the back of the wheel spokes as close to the hub as you can get with a rubber or plastic mallet (plastic works better)
Posted on: 2009/5/4 5:47
Not too shy to talk
From melbourne vic
I went to a bolt shop got two bolts that fit and four thick washers. Put the puller upside down and off it came. I used four washer because they tend to bend. It slips around a bit so it might take a few goes.
From Snohomish, WA USA
I have a tool that will pull that.
Posted on: 2009/5/4 6:20
'73 2 Door Sedan
Crower Stage 3 Cams/SS Valves
Forge CP Pistons/ Eagle Rods
Ford 8.8/Mini Spool/4.11
Thanks Datsa. You going to the drags next weekend?
Let's meet up and get this wheel off
Posted on: 2009/5/4 6:40
I believe the drags in Monroe are on Monday this week. (Memorial Day?) Not sure if I will be at Pacific. It cost me a bit more to run down there (gasing up the truck and pulling a trailer).
What is the distance across (diameter) from bolt hole to bolt?
Posted on: 2009/5/4 23:34
'73 2 Door Sedan
From gold coast QLD.
Amazing! Thought you where an old guy DD ha ha
Put the wheel back on,put the nut back on and wind on till the thread is flush with the shaft(and protected)now get your right knee under the wheel,left hand on top of the wheel,pulling back as hard as you can,hit the nut/shaft with a good crack with a hammer,may take a couple of attempts to get your timing and pulling motions in sink and if your left handed obviously swap hands and knees...be off in a flash.
Cheers
Posted on: 2009/5/5 0:06
From Oberon NSW {Bathurst}
Mine was a bit stiff to get off once but a 3 leg gear puller got me on my way.
Posted on: 2009/5/5 2:48
Cheers Peter.
nos4datsuns@bigpond.com
peter.maxsted@bigpond.com
0427 138 266
THIS YEARS RIDES & PROJECTS:
Tweaked 2009 AURION SV6(Daily)
