1981 Nissan Van - Wrecking?
From Sid-knee
What exactly is this: '81 Nissan Van
Is it a Vanette and is it likely to have an A15 or anything useful in it? Check out the pic, basically some Scandinavians own it and are going home on Friday, if it's not sold it'll be thrashed and burned.
Posted on: 2003/8/20 0:39
Re: 1981 Nissan Van - Wrecking?
From California
I think those use a Z series, at least in the U.S. If so, the remote water pump might come in handy.
Posted on: 2003/8/20 1:03
Looks like the Toyota Hi ace to me, I've seen them in South America, never in US.
________________________________
Posted on: 2003/8/20 1:47
From sydney australia
okay,looks like a vanette,easiest way to tell is to lift the passenger seat up,there's a catch on the front,& it hinges backwards.under the seat there's a gold coloured sticker,this will tell you if it's an a12 or an a15.look for either a12s or a15s.if it's an a12,it'll have a 4.889:1 h165 diff,if it's a a15,it'll probably have a 4.11:1 h190.
Posted on: 2003/8/20 2:13
From Mandurah WA
its not like a commer ?
Posted on: 2003/8/20 3:55
1984 Mazda 626 stocker..
Soon to be 32/36 weber powered
From NorCalifornia, up by Sac
What does the 's' in A15s stand for?
Posted on: 2003/8/20 4:08
I never saw an early 80s Nissan van in the USA before ...
Good question. I think it means "carburetted" but not sure. The parts books sometimes leave it off.
Posted on: 2003/8/20 5:11
From Sid-knee
It had, what appeared to be, exactly the same diff thats in my 12/'84 1200 Utility.
I have added another pic i got when i had a really quick look at it last night.
under car: diff, gb mudflaps... ???
Posted on: 2003/8/20 7:55
From DUNEDIN
yes the picture is a nissan c20 vannette which will have a12 or a15 engine the gear box will be a three speed some of the later c20/c22 had electronic ignition.
Posted on: 2003/8/20 8:56
From Melbourne, Australia
remote water pump???, tell me more please,
the "s" stands for carburetter for obvious reasons???
and if it has an a-12 or a-15 it will have a h-190 diff, the a-12 had 4.875:1 ratio the a-15 a 4.11:1 ratio, it is 90mm wider than standard 1200 diffs (requires flares or fwd offset rims to fit)
Posted on: 2003/8/20 9:15
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
