Browsing this Thread:   5 Anonymous Users
Diff Width
Hi guys, i know this has been discussed befor but i cant find the thread,
but can someone tell me the exact width of a 120y diff from rim mounting surface to rim mounting surface, and the same for a 1200 ute diff?
Cheers!
Posted on: 2009/5/18 14:58
Re: Diff Width
From Oberon NSW {Bathurst}
I don't know how wide the 120Y diff is but I just rolled one(H150) under my coupe(H145) and apart from spring plate and U bolt differences the widths are the same. Just use the 120Y hardware and you shouldn't have any issues.
Posted on: 2009/5/19 0:03
Cheers Peter.
nos4datsuns@bigpond.com
peter.maxsted@bigpond.com
0427 138 266
THIS YEARS RIDES & PROJECTS:
Tweaked 2009 AURION SV6(Daily)
Re: Diff Width
should be 1242mm from memory
Posted on: 2009/5/19 0:22
Re: Diff Width
From Vancouver, Wa
The 77 b210 (U.S. model) that i measured was around 51.75" drum face to drum face or around 1314mm (+/- 5mm for eyeballing it)
Posted on: 2009/5/19 5:21
1969 Datsun 1000 (B10)
1972 Datsun 1200 coupe (ADVAN)
1981 Datsun 210(B310) 4-door (sr20det)
1971 Datsun 1200 (sedan)
Re: Diff Width
as i have custom wheels and a 120y diff at the moment, and am thinking of upping to a 1200 ute diff, im hoping for a precise measure of both, as mines in the car makes it is hard to get an exact measure, if they are different with at all i may just get somthing else shortend, any sugestions, as id like to keep the weight down.
Cheers
Posted on: 2009/5/19 7:50
Re: Diff Width
From newcastle, NSW
I recently have put a ute diff(H165) in my 1000 2-door sedan, well worth the effort!
From memory the difference between the two diffs is about 65mm, i have the measurment some where.
Posted on: 2009/5/19 8:12
Re: Diff Width
yeah steveo, i know the 1200 is wider than a 1k diff, but i have a 120y diff in at the moment and its wider than the 1k diff, but was wondering if the 1200 is wider again or narrower
Posted on: 2009/5/19 8:42
Re: Diff Width
From Geelong, Vic
120Y and 1200 diffs are EXACTLY the same width
Posted on: 2009/5/19 9:13
Re: Diff Width
Thanks Mate, exactly what i was hoping to hear, the spring spacing is the same as well isnt it?
Posted on: 2009/5/19 9:21
Re: Diff Width
From Geelong, Vic
yep, but the mounts are slightly different
120y has a larger location hole than 1200 diffs as they use the rubber spacer things
Posted on: 2009/5/19 9:26
