« 1 (2)
Re: Diff Width
From Brisbane, Australia
Damper mounts will need to be welded to the diff if a sedan. .
Brake line also on the other side in a sedan.
Posted on: 2009/5/19 10:13
Re: Diff Width
From Adelaide S.A
Are you running the 120y borgwarner diff not the crappy little 120y jap spec one? I never broke locked bw 120ys with well over 100kw at the wheels and button clutch. I reckon the borgwarner would be as tuff if not tuffer than h165 ute diff and easy to find spares for them, try finding spare axles for a ute diff! Axle tramp is what kills them
Posted on: 2009/5/20 1:59
Affordable Performance and Mechanical Repairs
0421 221 821
Adelaide
Re: Diff Width
Precise measurement? B110 and B210 are:
* 51.36 in (1305 mm) outside brake drums
or
* 1185 mm axle flange-to-flange (less brakes)
Sedan diff to Sedan swaps. Coupe to Coupe swaps. No welding needed.
For B210, just use the B210 shock mounts and U-bolts. Fits onto a 1200.
Posted on: 2009/5/20 4:25
Re: Diff Width
i currently run one of the jap type 120 diffs, and ddgonzal, cheers for the measurements, btw its for a 1000 not a 1200, but the small changes needed for the 120y diff have been done
Posted on: 2009/5/20 5:15
Re: Diff Width
From Oberon NSW {Bathurst}
120Y diff in 1200. Use 120Y hardware.
jpg  uboltsetup.JPG (43.98 KB)
10229_4a1399ad726dc.jpg 256X192 px
Posted on: 2009/5/20 6:48
Cheers Peter.
nos4datsuns@bigpond.com
peter.maxsted@bigpond.com
0427 138 266
THIS YEARS RIDES & PROJECTS:
Tweaked 2009 AURION SV6(Daily)
« 1 (2)
