JDM NISSAN Production abolition information from Bprojects JAPAN.
From Mie Japan
Bprojects write down of JDM NISSAN Production abolition information to here.
We update the new information each time.
*There is not the inquiry of the nissan part number in our purpose.
*Bprojects think, we(datsun mate) more purchases from NISSAN to more reduce the production abolition.
We can ask them NISSAN-GENUINE-PARTS directly.
Bprojects JAPAN Email address.sunny_coupe110@yahoo.co.jp
NOTE: (Nissan parts number)-(part name)-(Application)-(Remarks)
*A series engine parts.
B7020-H1000- heater hose- B110.
10006-15M01- engine slinger- A series engine- all.
11826-H2300- rocker cover hose- B110 GX.
11826-95W00- hose blow-by- B10.
12207-H1001- bearing set crankshaft(maine)STD- A12.
13231-M0820- NISMO lighweight valve lifters- A series engine- all.
13264-G1360- valve rocker cover- A series engine- compatibility part exists.
16358-25610- hose connector- A12 GX- Twin carbs.
16361-H2300- throttle shaft- A12 GX- Twin carbs.
16361-H5500- throttle shaft- A12 GX- Twin carbs.
16376-H2300- bracket- A12 GX- Twin carbs.
14035-H2301- gx nanifold gasket- A12- gx oval ports.
16419-95W01- bracket fuel strainer- B110/B120.
16571-18001- rocker cover hose to air cleaner- B10
27070-G3460- heater hose connct- B120
*Interior parts.
25005-H1000(25005-G1660,68460-95W00)- clock cover- B110/B120.
48471-95W00- steering shell cover gray upper- B120.
48471-G1160- steering shell cover brown lower- B120.
68470-H1000(68470-G1060)- radio cover- B110/B120.
68910-H2500- dash pad- B110/B120.
*Exterior parts.
96301-18001(96301-27700,96301-28000)- out side mirrir RH- B10.
96302-18001(96302-27700,96302-28000)- out side mirrir LH- B10.
96301-H1000- out side mirrir RH- B110(early).
62312-H7425- S mark ownerment- B210.
62392-01A00- front ownerment- B11.
99099-55A00- mark rear SUNNY- B12.
99099-56A00- mark rear NISSAN- B12.
*Body parts.(panel)
62500-H7900- radiator core suport- B210- PB series.
65100-H5800- food bonnet- B210- PB series.
66802-H1001- grill cowltop RH- B110- sedan.
66803-H1001- grill cowltop LH- B110- sedan.
76486-H1000- retainer-sill moulding- B110.
*Chasis parts.(gear box, diff, axle, clutch, suspension)
08154-02510- bolt, hexagon- B110/B120- gear box mount.
11335-H6200- bolt, hexagon- B110/B120- gear box mount.
12314-M3300- flywheel lock washer- A10/A12(early).
30429-G1010- gadget, gear box to engine- B120.
30776-G1500- bracket clutch control- B110/B120.
38420-RS110- H165 NISMO LSD- B120.
40110-18000- ball joint, upper RH- B10/B20.
40111-18000- ball joint, upper LH- B10/B20.
40110-18001- ball joint, upper RH/LH- B10/B20.
40160-18000- ball joint, lower- B10/B20.
46582-H1000- sim ciutch control- B110/B120.
*Brake parts.
41060-H1025- front brake pads- B110- GX/GL.
41120-68225- MK-63 caliper repair kit- ***- for MK-63.
41128-21010- bleeder screw TOKICO- B10.
44100-H0500- brake wheel cylinder 11/16- B110- GX/GL.
44100-H3300- brake wheel cylinder 11/16- B210- GX/GL.
44155-88E00- bracket, rear caliper RH- J30.
44165-88E00- bracket, rear caliper LH- J30.
44155-97E01- bracket, rear caliper RH/LH- J30.
44155-N9500- bracket, rear caliper RH- S110.
44165-N9500- bracket, rear caliper LH- S110.
46010-H0129- brake master cylinder repair kit- B10.
*Electric parts.
25410-G1600 fuse box assy- B120.
25410-G1601 fuse box assy- B120.
*Other parts.
You can utilize these information!
Bprojects JAPAN Ebay store
Thank you, Endo
Posted on: 2009/5/31 4:17
Edited by ddgonzal on 2009/5/31 4:51:47
Edited by sunny_coupe110 on 2009/5/31 5:12:15
Edited by sunny_coupe110 on 2009/6/1 9:09:28
Edited by sunny_coupe110 on 2009/6/1 9:17:21
Edited by sunny_coupe110 on 2009/6/3 8:54:07
Edited by sunny_coupe110 on 2009/6/3 8:59:05
Edited by sunny_coupe110 on 2009/6/8 5:12:30
Edited by sunny_coupe110 on 2009/6/23 6:31:37
Edited by sunny_coupe110 on 2009/6/23 6:43:42
Edited by sunny_coupe110 on 2009/6/23 7:33:48
Edited by sunny_coupe110 on 2009/6/24 9:57:53
Edited by sunny_coupe110 on 2009/6/27 12:04:30
Re: JDM NISSAN Production abolition information from Bprojects JAPAN.
From Sydney, Australia
So these parts are now listed as NLA (No longer Available?)
Can someone communicate with Endo to get a better English translation for this post?
Posted on: 2009/5/31 6:10
From spaks nevada
Hey am new here and i have a ca18det also and i wanted to know if you could help me make a oildipstick for it
Posted on: 2009/5/31 6:24
YES -- these part numbers are NLA (No Longer Available) from Nissan Parts Business (Japan).
They may be available from Nissan Aus., Nissan USA, or Nissan Europe.
Posted on: 2009/5/31 7:32
From Mie Japan
Hello David,
Thank you for advice. and Im sorry in clumsy English.
It become the nice information if genuine-parts still sell in other NISSAN.
Add info, 44100-H0500(44100-H3300)
PS: Do I delete a thread in the case of the information that these do not deserve.
Regards, Endo
Posted on: 2009/6/1 9:16
From Mie Japan
Hello,
Add info; 08154-02510,11335-H6200....
Regards, Endo
Posted on: 2009/6/3 9:01
Endo-san, you may edit your post. Click the EDIT button
It looks like this: Open in new window
Then you can remove or add to the list.
Posted on: 2009/6/4 2:54
From perth
is there a parts listing for a wiper motor and arms with it.. i need one for me 72 sedan.. cheers.
Posted on: 2010/4/24 9:04
1200 sedan stock sleeper.
Aero Racing
From Fremantle, West Australia
Endo san
Do not worry about "clumsy english"
Your service to the Datsun community is a great thing. Where else could I find a B10 speedo in Kilometers?
Keep up the good work
Domo - Arigato
Mal
Posted on: 2010/4/24 12:30
