Browsing this Thread:   3 Anonymous Users
JDM NISSAN Production abolition information from Bprojects JAPAN.
From Mie Japan
Bprojects write down of JDM NISSAN Production abolition information to here.
We update the new information each time.
*There is not the inquiry of the nissan part number in our purpose.
*Bprojects think, we(datsun mate) more purchases from NISSAN to more reduce the production abolition.
We can ask them NISSAN-GENUINE-PARTS directly.
Bprojects JAPAN Email address.sunny_coupe110@yahoo.co.jp
NOTE: (Nissan parts number)-(part name)-(Application)-(Remarks)
*A series engine parts.
B7020-H1000- heater hose- B110.
10006-15M01- engine slinger- A series engine- all.
11826-H2300- rocker cover hose- B110 GX.
11826-95W00- hose blow-by- B10.
12207-H1001- bearing set crankshaft(maine)STD- A12.
13231-M0820- NISMO lighweight valve lifters- A series engine- all.
13264-G1360- valve rocker cover- A series engine- compatibility part exists.
16358-25610- hose connector- A12 GX- Twin carbs.
16361-H2300- throttle shaft- A12 GX- Twin carbs.
16361-H5500- throttle shaft- A12 GX- Twin carbs.
16376-H2300- bracket- A12 GX- Twin carbs.
14035-H2301- gx nanifold gasket- A12- gx oval ports.
16419-95W01- bracket fuel strainer- B110/B120.
16571-18001- rocker cover hose to air cleaner- B10
27070-G3460- heater hose connct- B120
*Interior parts.
25005-H1000(25005-G1660,68460-95W00)- clock cover- B110/B120.
48471-95W00- steering shell cover gray upper- B120.
48471-G1160- steering shell cover brown lower- B120.
68470-H1000(68470-G1060)- radio cover- B110/B120.
68910-H2500- dash pad- B110/B120.
*Exterior parts.
96301-18001(96301-27700,96301-28000)- out side mirrir RH- B10.
96302-18001(96302-27700,96302-28000)- out side mirrir LH- B10.
96301-H1000- out side mirrir RH- B110(early).
62312-H7425- S mark ownerment- B210.
62392-01A00- front ownerment- B11.
99099-55A00- mark rear SUNNY- B12.
99099-56A00- mark rear NISSAN- B12.
*Body parts.(panel)
62500-H7900- radiator core suport- B210- PB series.
65100-H5800- food bonnet- B210- PB series.
66802-H1001- grill cowltop RH- B110- sedan.
66803-H1001- grill cowltop LH- B110- sedan.
76486-H1000- retainer-sill moulding- B110.
*Chasis parts.(gear box, diff, axle, clutch, suspension)
08154-02510- bolt, hexagon- B110/B120- gear box mount.
11335-H6200- bolt, hexagon- B110/B120- gear box mount.
12314-M3300- flywheel lock washer- A10/A12(early).
30429-G1010- gadget, gear box to engine- B120.
30776-G1500- bracket clutch control- B110/B120.
38420-RS110- H165 NISMO LSD- B120.
40110-18000- ball joint, upper RH- B10/B20.
40111-18000- ball joint, upper LH- B10/B20.
40110-18001- ball joint, upper RH/LH- B10/B20.
40160-18000- ball joint, lower- B10/B20.
46582-H1000- sim ciutch control- B110/B120.
*Brake parts.
41060-H1025- front brake pads- B110- GX/GL.
41120-68225- MK-63 caliper repair kit- ***- for MK-63.
41128-21010- bleeder screw TOKICO- B10.
44100-H0500- brake wheel cylinder 11/16- B110- GX/GL.
44100-H3300- brake wheel cylinder 11/16- B210- GX/GL.
44155-88E00- bracket, rear caliper RH- J30.
44165-88E00- bracket, rear caliper LH- J30.
44155-97E01- bracket, rear caliper RH/LH- J30.
44155-N9500- bracket, rear caliper RH- S110.
44165-N9500- bracket, rear caliper LH- S110.
46010-H0129- brake master cylinder repair kit- B10.
*Electric parts.
25410-G1600 fuse box assy- B120.
25410-G1601 fuse box assy- B120.
*Other parts.
You can utilize these information!
Bprojects JAPAN Ebay store
Thank you, Endo
Posted on: 2009/5/31 4:17
Edited by ddgonzal on 2009/5/31 4:51:47
Edited by sunny_coupe110 on 2009/5/31 5:12:15
Edited by sunny_coupe110 on 2009/6/1 9:09:28
Edited by sunny_coupe110 on 2009/6/1 9:17:21
Edited by sunny_coupe110 on 2009/6/3 8:54:07
Edited by sunny_coupe110 on 2009/6/3 8:59:05
Edited by sunny_coupe110 on 2009/6/8 5:12:30
Edited by sunny_coupe110 on 2009/6/23 6:31:37
Edited by sunny_coupe110 on 2009/6/23 6:43:42
Edited by sunny_coupe110 on 2009/6/23 7:33:48
Edited by sunny_coupe110 on 2009/6/24 9:57:53
Edited by sunny_coupe110 on 2009/6/27 12:04:30
Re: JDM NISSAN Production abolition information from Bprojects JAPAN.
From Sydney, Australia
So these parts are now listed as NLA (No longer Available?)
Can someone communicate with Endo to get a better English translation for this post?
Posted on: 2009/5/31 6:10
From spaks nevada
Hey am new here and i have a ca18det also and i wanted to know if you could help me make a oildipstick for it
Posted on: 2009/5/31 6:24
YES -- these part numbers are NLA (No Longer Available) from Nissan Parts Business (Japan).
They may be available from Nissan Aus., Nissan USA, or Nissan Europe.
Posted on: 2009/5/31 7:32
From Mie Japan
Hello David,
Thank you for advice. and Im sorry in clumsy English.
It become the nice information if genuine-parts still sell in other NISSAN.
Add info, 44100-H0500(44100-H3300)
PS: Do I delete a thread in the case of the information that these do not deserve.
Regards, Endo
Posted on: 2009/6/1 9:16
From Mie Japan
Hello,
Add info; 08154-02510,11335-H6200....
Regards, Endo
Posted on: 2009/6/3 9:01
Endo-san, you may edit your post. Click the EDIT button
It looks like this: Open in new window
Then you can remove or add to the list.
Posted on: 2009/6/4 2:54
From perth
is there a parts listing for a wiper motor and arms with it.. i need one for me 72 sedan.. cheers.
Posted on: 2010/4/24 9:04
1200 sedan stock sleeper.
Aero Racing
From Fremantle, West Australia
Endo san
Do not worry about "clumsy english"
Your service to the Datsun community is a great thing. Where else could I find a B10 speedo in Kilometers?
Keep up the good work
Domo - Arigato
Mal
Posted on: 2010/4/24 12:30
