(1) 2 3 4 ... 1763 »
PERTH BOYS.. GO THE DATTO
From perth western australia
JORDAN LOVES MEN
Posted on: 2009/6/22 14:43
Edited by ddgonzal on 2009/8/6 3:24:39
Edited by popo1200perth on 2009/9/21 11:16:30
Edited by popo1200perth on 2009/9/21 11:35:25
Edited by popo1200perth on 2009/9/21 11:58:09
1000 coupe aka kb10
WHERE THE HELL IS ROBOCOP... DOES ANYONE KNOW
Re: needing some help sometime soon in perth cheers in advance.
From Coondle, WA Australia
Lowering the engine, as in making the mounts shorter?
This is so that you can fit the air cleaner that you have isnt it?
The 1k mounts are already short as, and if you drop it any lower, I would think that the sump will start rubbing on the cross-member. I dont think that you can lower the engine any.
When you saw Dundee, did he have anything to say on it. He is the 1k specialist in Perth.
I would think that the solution is to modify the intake setup somehow.
Sheds, well.... the pepsi challange is still on Dundee...
Posted on: 2009/6/23 2:05
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (A15et Death...)
SHED IS BUILT!!!!Stash sorted, now to do some work for once!
From Freo
you don't get discount on Pepsi for Being in the country Ruby.. haha..
Posted on: 2009/6/23 3:30
Email: BproAustralia@gmail.com
supplying Bprojects A Series and 1200 parts.
'68 Thou Wagon,(@the Paint Shop)
'67 Thou Wagon (to be lappo)
'69 2 door project,
A12A Project motor
A15 PSI Project Motor
'08 HD NighTrain 103ci 120HP
From antarctica
the motor is mounted with 1000 rubber mounts and roughly 2.5 inch angle to get the motor sitting back to the oringal spot i dont think you have any room to go down
get some su's or sidedraught webber
or it might clear with a filter that looks like this click me
how much room be between the bonnet and the carbie ?
Posted on: 2009/6/23 3:48
From Perth
I've been toying with the idea of moving the motor back
But I figured if it went down it would probably be too low inc the gearbox
Custom sump mods needed for both anyway
Posted on: 2009/6/23 6:45
Hey you know better that that. I dont need discounts. That would be cheating. You may alreay have a shed and a council that is not filled with F**Kbags, but you havent won yet....
Pepsi challange is on!
And becisdes, everyone always backs the underdog!
Posted on: 2009/6/23 8:07
i will be getting the measurements in like two seconds.there is 4cm from the sump to the cross member and approximately 3.5 from the carbie to the bonnet.
Posted on: 2009/6/23 8:51
1000 coupe aka kb10
i am hellllll wanting sidedraphts but dont have the money to buy them.. would rather webbers.
Posted on: 2009/6/23 8:52
1000 coupe aka kb10
From Freo
well in the past with a late sump they usually touch and need spacing up to clear..
I think the Mount brackets to the block must be different ones...
Posted on: 2009/6/23 9:20
'69 2 door project,
A12A Project motor
yeah i wouldnt have the foggiest idea ey i think jordy has the pics of the mounts on his for sale page if i find the link or if he still has it i will put it up for all to see and comment on what is wrong and how i can change it or get it changed.
Posted on: 2009/6/23 13:52
1000 coupe aka kb10
