Are all A-series oil pumps same spec?
Howdy?,
Over the past few weeks I`v be fitting a "new" second hand A15 to my 1000 sedan,
I think the motor is fairly good (maybe HM rebuild as it has HM stamped into the piston crowns).
When I got it fired up it sounded pretty good too (apart from some tappet noise)
However I did note that the oil pressure gauge (mechanical) was reading only halfway around the gauge (40psi) compared with three quarters (70 psi) with the old motor and pump.
I put this lower oil pressure down to "thinner" oil (no more BP corse+)
Today I decided to pull the oil pump out of the old motor and give it a go, low and behold three quarters around the gauge ( same as old motor).
Although the two pumps initally appeared similar the were a few slight differences the "old" pump has a "4" cast on the side the "new" has "14" cast on it, The "old" pump has "so4" stampped into it and the "new" pump has "R19" stampped into it,
But I think the major visual difference id that the "old" pumps drive gear extends about 5mm longer then the "new" also the pressure sender outlet is longer on the "old" one.
What should be the std. oil pressure be? and is there different models of oil pump for model A-series?
Cheers,
G O T H E D A T !!
Posted on: 2009/7/12 6:30
Jesus drove a datsun
`67 B10 Turbo white
`69 VB10 red
`71 S30 (240z) orange 432R style
`78 P330 (280c) president matte black
`76 p330 (260c) wagon silver
`96 Toyota Hiace 2.8 diesel LWB
Re: Are all A-series oil pumps same spec?
Yes they are all the same, except for the Nismo pump.
70 psi is too high. Are you using the same mechanical gauge?
Posted on: 2009/7/12 7:01
From northern 'burbs adelaide
60-70 psi when cold is more than alright. all my cars have run around this when cold then come back down to like 50-60 psi when warm depending on the oil ... its probably just a worn pump so just buy a new one or keep the old one in there
Posted on: 2009/7/12 11:00
70 psi is out of specification:
From the 1973 factory service manual:
* Regulator opening pressure: 54-60 psi
* Oil pressure at idle (650 RPM ): 13-17 psi
But 70 psi won't hurt anything.
[Edit] A15 oil pressure specificatin at idle is "More than 11 psi" and at 3000 RPM "54-74 psi". So there is a difference between A12 and A15 oil pump -- the regulator spring is a little different.
Posted on: 2009/7/13 0:46
Edited by ddgonzal on 2009/7/13 1:39:23
Cheers,
The gauge is the same unit used on the "old" motor.
However I never rely on the numerical reading as being gospel I only use it as a reference (1/4, 1/2, 3/4).
In my old motor ("old" pump) this gauge always read 2/3 - 3/4 from start-up, and close to off the scale at full noise.
Could have this pump been modified to suit its ex-drag racing set-up? (The previous owner of the "old" motor used to run 8000 rpm at 30psi boost on avgas)
Could there be potential engine damage due to exesive oil pressure?
Im thinking of running an oil cooler, will this effect oil pressure?
Cheers,
G O T H E D A T !!
Posted on: 2009/7/13 3:16
Edited by datsonovic on 2009/7/13 3:33:02
`67 B10 Turbo white
`69 VB10 red
From Sydney
Excessive oil pressure, long term is not a good thing for your engine. I would be chasing higher oil volume figures instead. Its better to have more oil for given time period.
Posted on: 2009/7/13 6:10
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
From Melbourne, Oz
If you do the L pump mod, should you open up some of the oil ports to reduce presure?
Posted on: 2009/7/13 6:17
"I hav achieved wood"
