Sunny B310 question
From Fremantle, West Australia
I have swapped the sunny's A12 for an A15 and 32/36 weber.
On the firewall I now have 2 unused connections(1/4" pipe). I think they are a fuel tank vent.
With the original carby gone what should I do with them?
Posted on: 2009/7/27 7:43
Re: Sunny B310 question
Use them -- they are not dependent on the carburetor.
1. Fuel tank vent
2. Fuel return line
You can cap the return line. But the tank vent should go to either a flow-valve or to a carbon cannister like the newer Aussie utes have.
Posted on: 2009/7/27 7:55
From sydney australia
I seem to remember that one went to the air cleaner & the other went to the rear pipe coming out of the block.If you want to use them, the engine pipe is an interference fit into the block, with a small set of stilsons (plumber's wrenches) you can remove them, just go gently as they're easy to crush. The aircleaner for the weber should have a small outlet you can connect the other hose to, if not your local auto parts place should have something you can make work, usually brass fittings.
Posted on: 2009/7/28 6:46
Thanks for the info
Posted on: 2009/7/28 11:30
From Albany, Perth Australia
since when did you have a b310 mal?
Posted on: 2009/7/28 11:41
1200 Smerf Mobile
hey the more the merrier.
Work is a toxic cesspit and the "Toxic Avenger" (sunny) is the perfect work hack
Posted on: 2009/7/28 14:17
wheres the pics of it?
Posted on: 2009/7/28 14:41
1200 Smerf Mobile
how many does it make at your house now...20 dattos
Posted on: 2009/7/28 15:51
1200 Smerf Mobile
