steering boxes
From campbelltown (sydney) australia
hi guys , just wondering if anyone has had much experience with changing steering boxes? mines stuffed and needs replacing coz ther is alot of steering slack, i have adjusted it and tightened it abit but its not enough, can i rebuild mine to fix it or will i need new one? also wat cars use the same box as 1200ute or is it only 1200ute one i can use thanks
Posted on: 2003/9/7 12:56
Re: steering boxes
From Invercargill, New Zealand
The 120Y and Sunny steering box is the same as all 1200's in NZ. Should be the case here in Aus too but Nissan Australia did do some wacky stuff that didn't happen elsewhere - like putting a 4 cylinder twin spark in a Skyline.
Posted on: 2003/9/7 13:16
Re: steering boxes
From Sydney, Australia
All 1200s use the same box. There are steering column differences but they are internal and parts do swap between the 2 kinds. The diffence relates mainly to the collapsible section inside the cabin. I'd recommend either looking for a late model 1200 Ute being wrecked, or get your one rebuilt. They just weren't designed to last for 30 years.
I didn't think any other models had the same one.
Chris
Re: steering boxes
From Melbourne, Australia
i had my box recoed by my mechanic but im sure when i looked into it the 120y and sunny boxes and connections were diffrent slightly
Posted on: 2003/9/7 13:17
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: steering boxes
From Collingwood. Victoria. Aus.
Yeh! the B310 (Sunny)has a rubber disc coupling joining the column/shaft to the box and the B210 ute's steering column/shaft attaches directly to the box.
Ute is a commercial vehicle, it wouldn't have had to meet certain ADR requirements.
I don't remember the 120Y configure.
Posted on: 2003/9/7 23:50
Never ever grow up
Re: steering boxes
From T'ville
yeh a mate of mine runs a 310sunny steering box in his 1200 coupe rally car the 310 box has a quicker ratio
I had considered putting a 310 sunny steering box and colum in my last ute, but sold it before it happened
Posted on: 2003/9/12 11:12
Re: steering boxes
Quite a regular
From Sydney Australia
Are you sure it`s the steering box ?
Have you checked your drag-link yet?
It could have all the play in that?
Worth a look !
Posted on: 2003/9/14 9:03
Re: steering boxes
yeah its th box i tightened it up with the screw thing but wat i wanna know is where i can get it rebuilt if tats cheaper than finding new one
Posted on: 2003/9/14 9:25
Re: steering boxes
From T'ville
fm1200 has a piont the drag link is the rod that connects the drivers side to the passengers side if there is any play in the holes it will be exadurated in the steering
Posted on: 2003/9/15 4:01
