« 1 2 3 (4) 5 »
Re: help a15 wont rev past 5800rpm :(
From perth airport
well im off to buy new coil new plugs fuel pressure gauge and get my rally tyre sorted :)
yer funny thing is i told the tuner its ment to rev to 8500 and hole reason i wanted the tune was to sort out the problem :( but thats wat happens when all the good carbie tuners go broke coz efi has taken over
Posted on: 2009/8/28 2:17
perth airport parking
Datsun 1200 ute A14
From perth
these guys are scared of engines s#itting on the dyno and getting blamed for it. they will always be conservative, and i dont blame them.
you need to have a deep discussion when you drop the car off.is it a race car/street n race/ daily driver? what do you want it to do? how do you want to drive it? are you looking for every last bit of power? or do you want it to be safe? how much maintainence are you willing to do? they need to know all this and more. the guy has to know exactly what you expect. if its not possible he will tell you then and there.
we get the other end "hey, you rebuilt the motor why did it s#it the tin" when they have the wrong carb wrong manifold wrong tune up wrong ignition and they fitted it in a paddock full of sand. my all time favorite is an engine built to rev to 7500 with a dead stock oil pan.
the bottom line is, if YOU didnt check it it might not be right
try the plugs, and big gaps are for low emmisions set em to std. the more power your trying to make the more critical the small stuff gets. MSD website has some info on plug gaps
racecar prep is all about checking, knowing, writing it down, deck heights, cam timing, comp ratio tappet settings,plug gaps it goes on and on....
you should have noted all your jets, emulsion tubes,chokes and acc squirter sizes
what happens if it blows up, you rebuild it and it makes 25 less HP. what were your original specs? "dunno" isnt an answer that will help you get back to where you were
everyone thinks this stuff is easy until they do it
dazza
give me a call if you want,home tomorrow
Posted on: 2009/8/28 11:16
Edited by dazza1200 on 2009/8/28 11:45:23
we will have a look tomoz jordy i am sure we can manage to get it to run a bit higher rpm, maybe inject a lil methanol? Hehehe or actually i could get my hands on a monster bottle of Nos... Hmmm maybe a new youtube video of ms.drift blowing up? LOL
Posted on: 2009/8/28 11:27
From Perth WA AUS
Do you know the correct timing to suit the cam?
Posted on: 2009/8/28 11:30
Datsun 1200 2Dr sedan.
From Perth WA AUS
Call Dazza Jordy!
Posted on: 2009/8/28 11:48
From perth
levey you buy a coupe?
Posted on: 2009/8/28 11:57
From Perth WA AUS
Yeah Dazza but might sell it cause I'll never get around to doing it up.
Posted on: 2009/8/28 13:25
From Albany, Perth Australia
yep and i might be getting it hehehe might be getting the wife slighty interested now hehe
Posted on: 2009/8/28 13:28
1200 Smerf Mobile
From W.A.
How good is the coupe cause I have a sedan if you want to swap!!!
Sory for cutting in datski
Posted on: 2009/8/28 14:07
From Perth WA AUS
Jeffroj, the coupe is not too bad for its age but you would be third in line for it.
Posted on: 2009/8/28 14:41
« 1 2 3 (4) 5 »
