(1) 2 3 4 ... 20 »
Chris's Rip Snorter A12 & Red B10
So since my B10 in PNG is buried in the depths of a 40ft container while I'm studying in Australia, I've been working on getting a decent performance engine to suit the little B10.
Just got a second job so HOPEFULLY I can keep things progressing at a reasonable pace.
At the moment I'm still pretty hesitant on dropping the A12 gear in the beaut little B10 as she's VERY nice as she is. So hopefully if things workout well another B10 will come up for sale and I can put the engine into that and the Red B10 can go back into storage.
Here are a few pictures to show what's going on. I'm about to rebuild the engine, nothing drastic just a new set of rings, a decent hone, a bit of measuring and checking to confirm everything is square (or round for that matter) and then I'll probably enlist the help of a mechanic to get everything timed in nicely.
Here goes. Listing off some of the goodies in no particular order. Just like my B10 in PNG most of these parts have been collected over the last year, big money for a one-off purchase, but not so hard on the wallet if they're bought over time. Bargains take time....mostly waiting & watching.
The black & white photo's are just as the camera is. It appears since the recent "Souf Ostraya" Datsun party my camera seems to have a hang-over (stuck on black & white).
Twin 45 Weber DCOE's on a manifold match ported to the GX head.
Bell-mouth velocity stacks - 82mm across the flare
Adjustable timing gear - awesome piece of craftsmanship
Double valve springs suited for race use - may or may not use these in this build
Ported GX head - Intake Ports Measure: 40mm x 31mm
- Exhaust Ports Measure: 28mm x 30mm
Lightened & Edged Crankshaft
Lightened perforated flywheel- I need to confirm it's weight yet on precision scales
Custom made extractors, used but were on a performance engine with a GX head & similar induction so it should perform
There are a heap of other things to go on but I'll update those in a few weeks. Here is the host for the engine......maybe.
Cheers
Posted on: 2009/9/7 14:57
Edited by clyons8 on 2009/12/22 2:03:50
Edited by clyons8 on 2009/12/22 2:13:04
Edited by clyons8 on 2010/4/9 16:03:20
Edited by clyons8 on 2010/10/7 12:26:34
Edited by clyons8 on 2010/10/7 12:54:00
Edited by clyons8 on 2010/11/29 10:07:18
Re: Chris's Rip Snorter A12 & Red B10
From Freo
who did you steal all those toys off??
Posted on: 2009/9/7 16:17
A15 PSI Project Motor
'72 CB750k,
Haha we all have our steady growing stash of toys.
These were "stolen" (if that's what you call it) from Kameari USA.
Posted on: 2009/9/8 0:07
Edited by clyons8 on 2009/9/8 0:43:22
From Perth WA
u could run it in the red one until u r ready to put it in your other one, then put the a10 back in the red one, or would that mean shipping a whole engine rather than just parts to PNG later.
Posted on: 2009/9/8 2:47
datsun 1000, Its not the size its how u use it.
From SA
Chris, mate...
that little b10 is screaming for that stinky a12... im more than happy to help out with the whole thing, getting that other car moved this week bud so if you want??
cheers
Dan
Posted on: 2009/9/8 5:33
full resto: 1971 ute check it out in projects
full resto: SR20 1973 coupe check it out in projects
Go Hard Or Go Home
From Wagga Wagga, NSW
What an elegant write up, not to mention the stylish car!
Posted on: 2009/9/8 8:40
Ryan(Zigzag) says:
mmmmm men
Jake(tuf-110) says:
i thought you might say that
Ryan(Zigzag) says:
its raining men
Jake(tuf-110) says:
oh its your day
Chris get a cheap running a12 with stock oval port a14 or a15 head fitted and run those quad mikunis, extractors, mild cam and flywheel.
Keep your A10 in the shed oiled up and save the beast for your other
project. Youll find the mikuni setup very responsive and all you need
to enjoy the feeling of a sports car with class.
Posted on: 2009/9/8 12:44
From pooraka,,adelaide
i say go the black and white pics
Posted on: 2009/9/8 21:48
620 ute -sr20det full irs
vanette-a15 turb
260c- daily
1000 4dr- a15
1000 4dr- project to be sr20
garage 910
Tomei GX manifold gasket - this only just fits
Cheapie oil pressure guage that I'll attach straight to the oil pump
Magard style throttle arrangement, need to make a couple small brackets to link them to the carburetor(s) throttle shafts
This should give you a basic idea of how they function
Posted on: 2009/9/9 22:46
From bend oregon
nice setup
Posted on: 2009/9/10 0:38
coming through hard
(1) 2 3 4 ... 20 »
