Are you Chasing Front Inserts?
From Oberon NSW {Bathurst}
Just a bit of info for those that don't already know:
Ford Corsair/Nissan Pintara 89/93 CA20/KA24 Front wheel drive Sedan, REAR shock inserts are same as 1200/120Y Fronts. I discovered this today when the rear shocks for my son's Corsair arrived. Ebay 4 sets left Buy now $44 incl post from Ultracheap Autos Kempsey. AC Delco Gas.
I don't know how to update Wiki so if anyone wants to it may be helpfull.
Still very lonely without Betty have to spend more time with my family
Posted on: 2009/9/24 13:41
Cheers Peter.
nos4datsuns@bigpond.com
peter.maxsted@bigpond.com
0427 138 266
THIS YEARS RIDES & PROJECTS:
Tweaked 2009 AURION SV6(Daily)
Re: Are you Chasing Front Inserts?
From Christchurch NZ
What do these cars even look like? just so I can put a face to the name.
Posted on: 2009/9/25 6:45
Forced Induction!
From Albury
Sounds good but I wander how soft they are compared to front shocks.
If they are too soft they may cause all sorts of horrible handling issues.
Cheers
Bob
Posted on: 2009/9/25 7:57
From Adelaide, Australia
Gas shocks off a corsair, they would bound and then send you too the moon on the rebound.
Gas shocks are good for beating up mates, holding up tailgates and wait can't think of anything else... they definitely don't belong on a 1200.
Better off rebuilding the orig wet leg setup. I did this with m/cycle fork oil and seals back in the day before I had a good job and they came up trumps.
Oil dampers are where its at. Tokico or koni, or Kyb oil/gas assist.
Posted on: 2009/9/25 8:13
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
From gold coast aus
hi guys thought would check this out at work in spare time
the u12 pintara / cosair fwd rear inserts in monroe are a 25-0229 and are type 2 with a body length 425 compressed 425 ext 627
the 1200/120y front inserts monroe are a 25-3418 and are type 1 with a body length 418 compressed 418 ext 612
both use same lock nut very similar in length but casair / pintara slightly longer hope this helps cheers buzz
Posted on: 2009/9/25 22:14
