« 1 ... 4 5 6 (7) 8 9 10 ... 16 »
Re: G13B into my KB10
seats are a very good choice Gav. well done.
the rocker cover would look better without the suzuki lettering but easily fixed
I suppose with a nissan or datsun badge or plate.
Gav- look forward to more pics. Its going to be a nice happy color with black
contrasting interior and perhaps wheels.
Posted on: 2009/6/9 14:40
From Sydney
I found little rust holes all the way along the passenger floor where it meets the sill. Found a big hole inside the channel that the seats bolts to.
This is section cut out.
New section welded in, not dressed at this stage.
Underside view, also not dressed. You can see the bit in the channel.
Posted on: 2009/6/10 1:24
From Sydney
The roof had crows feet, took it back to bare metal and then put etch primer on.
I took both guards off, replaced one due to rust. Welded up antenna and mirrior holes. Painted the inside black and all the surfaces that marry to the body in colur then bolted back on. I dont know if this is the correct way but worked well.
Posted on: 2009/6/10 1:31
I can see the color coming along soon it will look like a Weismann GT MF5 :p
jpg  Wiesmann.jpg (136.18 KB)
737_4a5a7f5c6f5bc.jpg 800X600 px
Posted on: 2009/6/10 14:38
Edited by D on 2009/7/13 1:27:16
Hi Gav, you mentioned a couple times about an engineer's requirements. Does 1300cc in a Datsun 1000 require engineering? I know the A15 does. A15 has 85HP compared to the G13BB at 79HP.
Good job on the car.
Posted on: 2009/7/12 22:56
From bundy, QLD
gti's have 79kw not 79hp. sorry, but had 2 for over 8 years, thats what i was into before 1200's.
Posted on: 2009/10/5 12:43
"71, 1200 Sedan a.k.a- old_spool- (project)
73, 1200 Sedan
71, 1200 sedan (parts car)
89, swift gti (gone now)
90, swift gti
From perth western australia
what would 79kw be in hp??? i dont know the differences at all.. anything would be alot better than the a10s lol
Posted on: 2009/10/5 15:28
1000 coupe aka kb10
WHERE THE HELL IS ROBOCOP... DOES ANYONE KNOW
From Christchurch
1 hp = .746 kw
so 79 kw = 106hp
Posted on: 2009/10/5 22:46
From Sydney
After a few months of feeling sorry for myself about the f#ck up with my paint. The engine bay came up good so I decided to move forward with the conversion and worry about paint later. Dan got the motor and box in and he has started wirring it up. I choose to use auto meter oil,water,boost guages and get my rev tacho modified to run a modern ignition system plus will be used in conjuction with a shift light. I done this as I wanted to keep the dash looking KB10.
Posted on: 2009/10/28 9:22
From Sydney
Engine sitting in, happy to see progress
In the middle of getting wired. You can also see my tunnel. I cleanned the welds and painted with POR15
Posted on: 2009/10/28 9:25
