Please Help me to clarify some unclear areas
From Sri Lanka
Hi Guys
Just Give me b210 Wiring Diagram if any one has or just post me the link from where i can get it
Thanks
Regards
Sumith
Posted on: 2009/10/15 6:58
Edited by Sumith on 2009/10/15 7:39:05
Re: b210 Wiring Diagram
Posted on: 2009/10/15 7:17
PLease Help me to clarify these
From Sri Lanka
Hi Guys
Just going through the wiring article and there are some unclear areas for me , please help me .ill post them on thif discussion
Thanks
Regards
Sumith
Posted on: 2009/10/15 7:37
Re: PLease Help me to clarify these
From Sri Lanka
Hi Guys
IG (ignition/run) This connects to two things:
* Directly to Ballast Resistor (non-coil side). This is spelled "Resister" in some Nissan publications. If equipped with optional factory tachometer, this circuit goes through tachometer
Means this wire connection is going to the ignition coil negative side what they mean by Ballast Resistor ?
clarify me in simple way please
Thanks
regards
Sumith
Posted on: 2009/10/15 7:42
From Melbourne, Oz
Its a white block with a wire coing out iether end neer the distributer. its not nesicery with elctronic ignitiom
Posted on: 2009/10/15 7:57
"I hav achieved wood"
This is the ballast resistor, #1 in this photo:
Remember the article is about Datsun 1200 (B110) unless otherwise stated. But B210 is similar. Wiring colors may differ. Tachometer wiring may differ.
Posted on: 2009/10/15 7:58
From Sri Lanka
Hi Guys
OK clear ,means it has got 2 connectors (coil side and non coil side) isn't it ?
Thanks
Regards
sumith
Posted on: 2009/10/15 8:06
