« 1 2 (3)
Re: 63a fitment.. what do I need?
i thought he was? might be wetdriftwarrior.... im confuselded too.
Posted on: 2009/10/26 20:52
From Melbourne, Oz
Its a 63a for a series. even biger then 60series.
Hey DD We never got them Here, so may be a problem. Did the 63A come in any vans??
Might get an l16 clutch and Redowl the flywheel, want to put a a12 flywheel in anyhow.
Posted on: 2009/10/27 11:22
"I hav achieved wood"
ask lagwagon, hes using a series clutch on l series 5 speed, might be similar info
Posted on: 2009/10/27 11:57
From Toowoomba, Qld
any clutch joint will be able to make the plate you need, its just an l series centre with 180mm(from memory) outer diametre. l series standard diameter - 200mm, a series - 180mm.
I bought one a few years ago, the Australian part# is NSD030U and is made by DAIKIN
It was a made to order thing so I dont know if they can still supply them
its OD 180mm
ID 125mm
SP 24
MD 25.6mm
the tailshaft front spline is also the same as 160/80/200b. get a shaft from the wreckers and put the diff end on it.
Posted on: 2009/10/27 12:40
From Quairading, Western Australia
63A 5 speed has the same splines as a 3N71B (3 speed auto) 120Y
so grab a H145, H150 or BW 120Y auto tailshaft - might need to be shortened though!
Posted on: 2009/10/28 0:17
It is the same tailshaft, same Nissan part number (we got both autos and 63a gearboxes here).
For a clutch disc, try Nissan:
* 30100-K0500 ASSY-DISC,CLUTCH 63A 5-SPEED(COUPE) B210 USA, JDM $66.07 USD
* superceded 30100-H5801
The pressure plate is:
* 30210-N1600 ASSY-COVER,CLUTCH 63A 5-SPEED(COUPE) B210
Posted on: 2009/10/28 2:41
From Melbourne, Oz
Awsome thanks a'lot fellas, pretty much cover it all there!
Posted on: 2009/10/28 6:03
« 1 2 (3)
