« 1 (2) 3 »
Re: Help me start my A14!!!
yes, littledarkone is right. You should not proceed until you verify those two items. They are the foundation.
Posted on: 2009/10/29 2:22
From Perth WA
also might be flooded, put a battery charger on for a while to get the cranking speed right up, especially on a tight new engine, while the extra unburnt fuel evaporates for a couple of hours.
Posted on: 2009/10/29 3:55
datsun 1000, Its not the size its how u use it.
From sydney australia
Is the float level correct? If the float is too high, or the needle & seat stuck open, the fuel will run up & into the inlet manifold. There's a small window on the forward side of the carby with a little dot in the middle, the dot is the correct level of fuel for the carby. Maybe it's not starting because the plugs have fowled up. There's a screw on the rocker cover side of the carby that controls the idle mixture, turn it in (clockwise) to lean out the mixture, turn it out (counterclockwise) to richen the mixture.Check the firing order,too. That back fire sounds like you've got 3 & 4 plug wires crossed, remember its 1-3-4-2, not 1-4-3-2. I fell victim to this with my first 1200,mainly because my brother-in-law was a Beetle nut & he hooked up the plug leads. Also,do you have power to the idle cutoff solenoid. It needs a 12 volt power source to open the solenoid.
Posted on: 2009/10/29 9:41
From Lisboa-Portugal
Littledarkone is right, i didn`t check the timing. The spark is not "aligned" with the valve opening. I will check the troubleshooting section and hopefully it will start. Ì can wait to film the first start and dedicate to all of you.
THANKS EVERYONE!!!
Posted on: 2009/10/29 9:57
Historic day - 29th October 2009 at 13:04 the engine started. What a beautifull sound, after 2 years rebuilding it. Later i will post a video dedicated to all of datsun1200.com members, is all because of you guys i managed to put a old engine running...
Thank you all once again.
Posted on: 2009/10/29 14:43
As i promissed here`s the video dedicated to all of you.
Obrigado.
Posted on: 2009/10/29 15:28
Re: A14 ENGINE STARTED!! Thank you all!!( with video)
From SE Melbourne
Ignition seems to be the problem with most non starters in my experience...particularly in the pre-computer age
Posted on: 2009/10/29 21:11
Mildman, Datsunless
From Townsville, Qld
That's great new Bandit!
Posted on: 2009/10/30 1:15
From Perth WA
. First kick! interesting air intake filter setup.
Posted on: 2009/10/30 1:40
Vanette top hat, I got one and was thinking about ways to use it years ago.
Posted on: 2009/10/30 3:30
« 1 (2) 3 »
