Help me about manometer..
From Selangor, Malaysia
Hi guys,
I plan to do carb balancing using one of those DIY fluid manometer. I've found quite a few on the net, something like this Marty Igzanito DIY Manometer PDF with Pics [url]http://www.zivney.net/library/carbsync.pdf[/url] and his Web version with only 1 pic [url]http://www.powerchutes.com/manometer.asp[/url].
I believe I can build the manometer, but I have one big problem. Where do I connect the 2 ends of the manometer tube? I've been searching high and low in the net, but so far I couldn't find any that shows me how to do it. Some indicate that the manometer needs to be connected to the carb vacuum ports but where the heck is this vacuum port? My carb model is Mikuni Solex 40PHH.
And if the carb itself doesn't in balance..how do i balance it?
Thanks in advance.
Posted on: 2009/11/1 4:05
dying to learn A series..help me :)
Re: Help me about manometer..
You will use it with twin carburetors. If you have a single 40PHH there is nothing to synchronize.
Posted on: 2009/11/1 4:09
i'm sorry ddgonzal,forgot to mention..yes i'm using twin Mikuni PHH40 carburetors..how to synchronize it?
thanks.
Posted on: 2009/11/1 5:41
I've never used one, don't you just stick the hose down the carburtor throat?
Most use something called Uni-Syn.
Posted on: 2009/11/1 6:23
From Melbourne, Oz
on motocycle carbs the hav an actual plug to put them on with a vacume signal. I recon on a weber style carb you will need a taperd plug to sit in the mouth of the carb?
Posted on: 2009/11/1 6:53
"I hav achieved wood"
From Toowoomba, Qld
if you dont want to go to too much trouble, just put one end of a vacuum hose in your ear and the other end into the throat of the carb, it's hard to explain but the pitch of the sound you'll hear will differ if the carbs are not synch'd, just adjust one till it sounds like the other.
with a bit of practice you'll get it exceptionally close to perfect.
Dave
Posted on: 2009/11/1 7:34
i've just made the manometer..and put the both end of the tube into the throat(1&3)..but nothing happened, i guess this kind of tool is not suitable for this Carbies?
Pendles,thank you for the method,this method need a lots of attention and focus..i will surely try it this weekend.. thanks.
what does it mean actually when it comes to carburetors balancing i.e Solex 40PHH in my case,?where should i adjust it? is it the Idle Jet Screw?
thanks..
Posted on: 2009/11/1 12:09
balance it with the idle speed screw.
Posted on: 2009/11/1 16:25
thanks ddgonzal..
Posted on: 2009/11/2 3:11
From Perth WA
great tip there pendles.
Posted on: 2009/11/2 4:02
datsun 1000, Its not the size its how u use it.
